| Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania. |
12-11-2012, 3:24 AM
Originally Posted by skirvy22
question...i just bought the pro 106 and uploaded york county pa and havent heard anything. I programmed it with win500. I had the same issue with my p96 radio and had to adjust the tables. Do i need to do the same with this radio? thanks.
You don't need to adjust the tables with the 106. It should work fine if you just download it from RR.
12-11-2012, 11:30 AM
This...
York is the one system that always worked on my GRE scanners without any tweaking. Dauphin, however, was another story...LOL.
FTM-PTB-EGH
West Shore Bureau of Fire
996XT/PSR-600(x2)/PSR-500/Pro-2096/Pro-2055/Pro-97/Pro-2026/Pro-2036
12-11-2012, 11:24 PM
Originally Posted by hosehead88
This...
What kind of tweaking did you have to do?
12-13-2012, 7:54 AM
For most of my GRE made scanners, I needed to add all frequencies, not just talkgroups. For the RS Pro-2096, I had to make additional changes: Dauphin County - Motorola p25 System
FTM-PTB-EGH
03-05-2013, 8:21 PM
I have a Radio Shack Pro-97 and Pro-2051. Are these compatible with the York County system for listening to City of York police? I am a chaplain for YCPD and want to keep tabs on what is happening when not on duty but only radio we have is in chaplain's vehicle.
03-06-2013, 2:06 PM
Neither is a digital scanner so they will not work with York.
FTM-PTB-EGH
03-06-2013, 3:43 PM
if you come up with a radio shack digital scanner , i would be happy to program it for you. if you buy brand new at radio shack they will program for you but you will get every thing in york co. pro 197; pro 106; pro 2096; pro 96. hope this helps check e-bay
pro 106; 2-pro 197's; pro 2096; pro 96; REGENCY ACT-E 10H/L/U SCANNING since 1975 WRIGHTSVILLE YORK CO. PA
03-06-2013, 3:47 PM
Chaplin Tom has a portable.. Why not you?..
PSR800 2 , PSR600, PSR500, PRO2096, PRO106, BCD 296D P25 card, Commercial FCC license, Ham General, FAA Private Pilot, Business Owner, APCO Certified Tech.
03-06-2013, 3:48 PM
Listen to the York County Police feed on Radioreference.com
03-07-2013, 1:43 PM
As I understand it Chaplain Tom is on call pretty much 24/7 for several county departments including one of the largest Regionals.
City has a group of Chaplains who are on call 2 - 4 days per month. The City can't afford take-home portables for every Chaplain.
My posts may be few but I've been on the air in public safety service for a quarter century and then some...
04-07-2013, 7:54 PM
Program My BCD396XT??
jimsmowin - or anyone in York... need help, can someone local program this new scanner for me?
04-08-2013, 3:26 PM
i can not do bearcat scanners
04-08-2013, 3:58 PM
I used to be that way about Uniden, no more..
Reason: my bad--thught it meant york Maine..ooops
04-08-2013, 4:06 PM
I am looking into the same scanner, was told RS on Loucks Rd may be able to offer a clone program for the digital trunking frequencies used by York Co. You would need to call them (or just go there) with a CAT number to see if it is compatible with the base system they use as they said they can do 'some' scanners that are not from RS.
RadioShack
351 Loucks Rd York, PA 17404
(717) 848-6283
04-09-2013, 2:00 PM
RadioShack
(717) 848-6283
Went there today and they can clone the ones that use a 3.5mm jack. Mine has a small two or four pin adapter that plugs into the side.
04-10-2013, 7:19 AM
That stinks! Guess there's no adapter that can successfully be used? (will research)
With this new information I reckon I will also continue to pursue upgrading my membership here so I can access the downloadable programming software offered, the stated rate is very reasonable, imo.
04-10-2013, 7:59 AM
I can do it.. What is the make and model #..
call me at 717-eight eight one- 9200
04-11-2013, 8:13 PM
Finally
So I finally broke down and paid the $37 for the adapter cable at tye Shack and upgraded my RR subscription and finally got it programmed!
04-11-2013, 9:02 PM
Right on! Hey this cable wouldn't by any chance be a USB PC Interface would it? I ask because the seller where I am planning on getting my sons scanner offers this cable for a little over 20 bucks.
Reason: to add
04-14-2013, 5:07 PM
If you still need assistance, let me know. I live just outside of Red Lion and Yoe.
