Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 02-10-2008, 02:25 PM
Question bucks co.programing pro96
i've tried everything!can't get bucks at all.i tried table,normal,splinter.etc... nothing works.i get montco,philly lower merion's EDACS,but no bucks.need help!
Old 02-10-2008, 02:49 PM
Default Well....
Well, I'm looking at Bucks County now and it appears to be a Motorola II Smartzone, so are you actually entering it as a Mot/Motorola system?
I'm no 100% sure on how to program the Pro96, but I'm sure it would be a little similar to the BR330T.
I know on the BR330T, that system would be programmed under Mot system and UHF band.
Perhaps the Pro 96 does it that/this way also.
Old 02-10-2008, 05:12 PM
call radio shack they have a sheet on how to program all bucks county. i lost my sheet ill try to find it. im over here in levittown..
Old 02-10-2008, 05:13 PM
i called the one in oxford valley mall
Old 02-10-2008, 07:12 PM
fmon's Avatar
1. PGM>TRUNK then MODE to MOT
2. press FUNC + 2 and key in 501.0375 (Base freq) then press ENTER
3. key in Offset 380 then press ENTER
4. using UP or DOWN button set step to 25.0KHZ then press ENTER
5. press FUNC + 3 then UP or DOWN button to Table then press ENTER
6. press PGM and key in the first freq then press UP button
7. repeat step 6 until all required freqs are entered.
Press SCAN and insure a + is under the bank number until ID's have been programmed. If a - is present, press FUNC + 5 to change scan mode to Open (+).
Frank
RR Wiki Programming Shortcuts
Old 02-10-2008, 09:59 PM
im almost positive radio shack told me bucks is pre programmed in one of the banks
Old 02-10-2008, 10:32 PM
fmon's Avatar
Yup, Folder 5 bank 8, Phily's in bank 9. However, I just opened that folder in Win96...table isn't set for Bucks.
Frank
Old 02-11-2008, 12:06 AM
im not familar with scanners yet, but what are folders?
also does that philly bank have helicopters freq
are local news helicopters stored in there?
sorry for all the questions but can you list all the frequencies stored in there?
i cant wait to pick one of these up!
Old 02-11-2008, 09:36 AM
fmon's Avatar
This is a statement from RR Wiki regqrding V-Folders
V (for 'Virtual') folders contain data for all 50 states loaded from the RadioReference database. However, several changes have occurred since the initial release of these scanners, but you can update them.
The newer scanners should have an update in V-Scanner which has the table set correctly for Bucks County.
No, only the trunking system.
No.
Code:
Folder 5
Bank System
0    Delaware State Wide 800 Smartzone
1    Anne Arundel MD 800 Smartzone
2    Balt City 800 Smartnet
3    Balt County 800 Smartnet
4    Frederick County 800 Smartnet
5    Howard County 800 Smartzone
6    Upper Maryland Eastern Shore Consortium 800 Smartzone
7    Ocean City 800 EDACS Standard
8    Bucks County 500 Smartzone
9    Philly 800 Smartzone
If you intend to purchase a new Pro-96, you may want to consider a GRE PSR-500 instead. Both scanners are made by GRE and both sell for 500 bucks. PSR-500 has all new technology while the 96 technology is nearly 5 years old. The 500 needs to be ordered from scanner dealers...they are not stocked by Radio Shack
Frank
Old 02-11-2008, 04:51 PM
thats what i hear, ill have to check it out!
Old 02-11-2008, 06:47 PM
yes bucks is in bank 8 but maybe its erased from yours. did you buy it from radio shack? or a private seller?
Old 02-12-2008, 04:56 PM
say if philadelphia wasnt stored in the scanner, what number would i put it the radio as the frequency
does the prestored frequency include all of this
http://www.radioreference.com/apps/db/?sid=833
Old 02-12-2008, 08:53 PM
fmon's Avatar
Program the red and blue freqs on the data page. If you only need the FD/EMS, use the two freqs for it and the talkgroups for that agency.
If you want Law, use the two reds and the blue and law talkgroups.
No on prestored freqs, the DB has been updated since V-Scanner files were made.
This is the freq list.
Code:
Phil PA TRS      866.10000      MOT      0.0    D
Phil PA TRS      866.28750      MOT      0.0    D
Phil PA TRS      866.33750      MOT      0.0    D
Phil PA TRS      866.36250      MOT      0.0    D
Phil PA TRS      866.58750      MOT      0.0    D
Phil PA TRS      866.68750      MOT      0.0    D
Phil PA TRS      866.78750      MOT      0.0    D
Phil PA TRS      866.81250      MOT      0.0    D
Phil PA TRS      866.83750      MOT      0.0    D
Phil PA TRS      867.06250      MOT      0.0    D
Phil PA TRS      867.08750      MOT      0.0    D
Phil PA TRS      867.11250      MOT      0.0    D
Phil PA TRS      867.35000      MOT      0.0    D
Phil PA TRS      867.56250      MOT      0.0    D
Phil PA TRS      867.58750      MOT      0.0    D
Phil PA TRS      867.81250      MOT      0.0    D
Phil PA TRS      867.83750      MOT      0.0    D
Phil PA TRS      867.86250      MOT      0.0    D
Phil PA TRS      867.93750      MOT      0.0    D
Phil PA TRS      868.06250      MOT      0.0    D
Phil PA TRS      868.08750      MOT      0.0    D
Phil PA TRS      868.28750      MOT      0.0    D
Phil PA TRS      868.31250      MOT      0.0    D
Phil PA TRS      868.33750      MOT      0.0    D
Phil PA TRS      868.58750      MOT      0.0    D
Phil PA TRS      868.78750      MOT      0.0    D
Phil PA TRS      868.56250      MOT      0.0    D
Phil PA TRS      868.83750      MOT      0.0    D
Frank
Old 02-12-2008, 09:21 PM
wat are them unhighlighted freq's
Old 02-12-2008, 09:26 PM
fmon's Avatar
From our previous
The list is from the preprogrammed list for Philly.
Frank
Similar Threads
buck's co. pa. pro96 programming ? ahrensfoxfd Pennsylvania Radio Discussion Forum 4 02-12-2008 09:53 AM
The official PRO-96 / BCD396T comparison thread Voyager General Scanning Forum 164 01-08-2008 09:12 AM
For Sale Pro96 and Uniden BC250D W/card billybob Old Classifieds Archives 1 07-22-2005 07:13 AM
RadioShack Pro96 and Software hcpholder Tennessee Radio Discussion Forum 3 07-29-2004 06:26 PM
