Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 05-25-2008, 01:14 AM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
Default My Pro 97 and GRE PSR 500 Shack Install
I've posted pics before where I had my RS 97 installed in my truck, however, After checking It was better that I had a permanent install hidden under the dash in there so I too my RS 2025 that was in the house and istalled it mobily (which is posted in here also) and then ordered me a GRE PSR 500, Scantenna and 75 feet of LMR 400 (Scantenna pics are here in this forum as well) and then took My 97 back out of the truck and am using it in the house for "LOCAL STUFF" and then I've got my GRE PSR 500 Set up to roam and scan the state Digital statewide local stuff but all digital that nothing else will recieve, In the other room I have an older Bearcat Uniden 147 that is used just for "LOCAL" analog stuff...So here are the latest pics of my 500 and 97 in action installed in my house, I just took my mobile stand mount that I had under the seat and installed it with screws in the house.. Here are the pics..Let me know what you all think....
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 05-25-2008, 01:15 AM
btritch's Avatar
One More
Brian
Old 05-25-2008, 05:18 PM
NoRide's Avatar
It works for you and that's all that matters. Nice.
My Humble Shack
(2) Uniden BCT-15 (2) RS Pro-97
Butel ARC15, Win97, Bearcat ESP-20 Ext. Speaker
ST2 Scantenna, RS 20-032, RS 20-176, RS 800MHz, Diamond RH77CA, Wilson 301111 Yagi
Old 05-26-2008, 04:25 PM
I see you changed your lcd to green.
Old 05-26-2008, 04:32 PM
btritch's Avatar
I haven't changed it, That's what it was already set at when I got it, I didn't know I COULD change it, Is THAT possible?
Brian
Old 05-26-2008, 05:01 PM
Mine came Bright orange... Yours are the first i ever seen green. They are green right or is it an illusion?
Old 05-26-2008, 05:35 PM
Astro25's Avatar
It's probably orange. Look at the Pro-97 screen - they are natively orange, yet it appears to be greenish in effect from the camera. The PSR also shows about the same color...
Old 05-26-2008, 06:03 PM
Thats what i`m thinking also.
Old 05-27-2008, 01:55 AM
Paragould huh? My Cousin from Pocahontas works at the Hospital In Paragould.
BTW I like your install
PRO-106
PRO-97
Old 05-27-2008, 02:14 AM
mancow's Avatar
What type of coax is that? It looks like Andrew FSJ 1/4".
If so, I would suggest a cheap jumper of some RG-58 type. If you flex that stuff much at all you will end up with internal fractures of the center conductor since it's made of copper flashed aluminum.
Old 05-27-2008, 08:46 PM
btritch's Avatar
its lmr 400, i thought about an rg 58 jumper about a foot or two lng but how muchloss will there be with it?
Brian
Old 05-27-2008, 09:41 PM
KC0QNB's Avatar
Send a message via AIM to KC0QNB Send a message via Yahoo to KC0QNB
I was wondering how long that bnc connector will last with the LMR400 hanging off of it, just looks like a bad idea to me, I really don't think you will notice any loss if you use a jumper of something lighter, maybe even do what I am considering, making a "patch panel" of sorts and use some RG174 or RG58 for the interconnects, yes I know the more connectors you use the more loss you will have, but will it really matter for anything other than EME or other weak signal stuff?
If I am mistaken please educate me and the others, I know external antennas for GPS receivers use real small cable at 1500mHz, as do external antennas for cellphones at 800-900mHz.
For what it is worth I was in Paragould back in the seventies, my dad knew one of the manager types at the Monroe shock plant.
I can't recall the name right now, it was unusual as I recall, also hung out with a banker with the last name of Jackson and his family as I recall.
ICOM IC-2200H, IC-2100H, 2x Bearcat III, old PRO-46, hasn't failed me yet.
I am not affiliated with any of the companies, whose links I provide, on this or any other forum.
Grid Square DN90WW
Old 05-27-2008, 10:05 PM
gatorhater's Avatar
Thumbs up
Cool! I really like the Alarm Bell.
Don't Steal, the Government Hates Competition!
Old 05-27-2008, 10:20 PM
Just as worrisome to me would be the stress it is putting on the male BNC on the radio itself. I've had problems in the past with them coming loose and disconnected from handhelds because of stress. And no, I don't pick up my radios by the duck.
"Man up and drill those holes!"
Old 05-28-2008, 12:20 AM
btritch's Avatar
The alarm bell is my alarm clock, sounds like an old fashioned school bell.. I love it..
So, Should I use a RG 58 jumper to relieve stress or what does one recommend>
Brian
Old 05-28-2008, 12:53 AM
I think I would. I mean, it may not matter. Some radios take a beating and never budge. But if your luck is like mine, just a few months of changing between the duck and the coax will break that connector loose, so anything you can do to reduce stress on the connector is a good thing. There should be no significant or notable loss from adding the jumper.
Old 05-28-2008, 01:02 AM
mancow's Avatar
A short jumper won't induce any noticable loss. They use them inside cellular and other professonal setups for similar reasons.
Old 05-28-2008, 01:21 AM
Exactly. Although I am always a wee bit hesitant to say that it absolutely will not induce loss. Just as soon as I say that, then they try it with a defective jumper and call me a liar when they can't hear anything.
HTML code is On
Similar Threads
Looking For A Gre Psr--- 500 lugoffman Old Classifieds Archives 1 04-09-2008 11:40 PM
PSR 500 scanning/receiving strangely rawman GRE Scanners 9 03-19-2008 10:24 PM
Scanning Oakland/Macomb with Pro 97 Ch1ronTL34 Michigan Radio Discussion Forum 7 12-26-2006 09:50 PM
