| Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. |
08-17-2008, 01:45 PM
KI4LIV mobile 2007 Dodge Charger SXT install
Yaesu FT7800.
Uniden BR330T being controlled by Uniden RH-96.
Radio Shack amplified speaker for the BR330T.
Uniden speaker in the back seat on the floor hump for the FT7800.
Driver's side door view
View from the driver's seat
View from the passenger door
Doesn't interfere with the passenger's leg room!
Speaker for the Yaesu FT7800 mounted on the back seat floor hump
Angle view of the antennas:
Straight-on view of the antennas:
Low-light shots to be taken this evening. Any questions or requests for specific photos, just ask!
--Light is faster than sound... Perhaps that explains why some people appear to be intelligent - until we hear them speak!
08-17-2008, 02:34 PM
Nice Ride...
RESCUE4NFD
Mike in Garland,Tx.
www.Careflite.org
08-17-2008, 03:38 PM
i really like the idea of the dual remote head mount, you did a very nice job with your new install. I will likely replicate this. now you need to patch the radio into your car stereo with a line amp or AUX
K7MHI
08-17-2008, 03:48 PM
I'm reserving that for my cell phone - I like to listen to internet streaming radio stations via my cell phone while driving :-) No commercials :-)
08-17-2008, 04:12 PM
Very nice! I've been waiting for you to post these pics since you announced you were going to re-do the install! Looks really good! I'm guessing that is your wife sitting in the passenger seat, to show the clearance? And how is the BR330 working out with the RH96?
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
08-17-2008, 04:42 PM
Actually that was ME sitting in the passenger seat - I figured I'd be a better test subject since I have much larger legs :-)
BR330 is working out well with the RH96! Just be sure you are running the latest firmware - I wasn't at first and was a little bent out of shape until I realized!
08-17-2008, 05:21 PM
Badass install! Love your car!
BSA Eagle Scout
ERS 456, IPN LAX351
FD Explorer
XTS5000, Astro Saber,
HT1000 x2, Visar
Radioshack Pro95
Uniden BCD396T, BC340CRS
08-17-2008, 07:25 PM
Very nice install job!!! I've have virtually the same setup and wonder how did you "solve" the issue of having to turn on the scanner and the BC-RH96 remote head individually? I've been search for a way to turn them both on with one switch but so far have struck out.
Metrofire31
Atlanta
08-17-2008, 07:37 PM
RR Moderator
That looks great Jon. Nice and clean and love where you put the speaker, I have to do that for the mobile one day.
Ron
08-17-2008, 07:41 PM
Since the BR330T is right inside the arm-rest cubby, I simply turn it on/off there. The BR330T uses hardly any power anyhow.
08-17-2008, 07:42 PM
Ron
Which one? :-) The one in front of the shifter for the scanner or the one in the back seat for the FT7800?
08-17-2008, 08:00 PM
RR Moderator
For the 7800 behind the seat. The head really looks good there.
Ron
08-17-2008, 08:09 PM
Here's the promised low-light shot.. Thanks everyone for all the comments so far :-)
08-17-2008, 08:16 PM
Corkle.usmc
The best part of the install is the back window semper fi.
08-17-2008, 08:50 PM
Very nice looking! I love the wire looms to cover everything up. What ever you do, don't mention if your ham radio can do out of band!
BTW - Where in FL are you? I'm former JAX.
/\/\|k.e
WQKM383
Support Your Local Search & Rescue Team - - - Get Lost!
08-17-2008, 09:16 PM
what type of antenna's are you using? nice set up, I just bought a 7800 at the huntsville hamfest on saturday
08-17-2008, 09:59 PM
If I remember correctly it's a Diamond 7500NMO for the FT7800.
The scanner's antenna is an RF Products labeled Antennex.
Brevard County - Cocoa Beach area (Merritt Island).
08-18-2008, 09:34 AM
Actually, there is a way. If you are powering them both from a cigarette lighter socket, plug them both into one of those multi-outlet splitters that has a master on-off switch. Use that switch to toggle the power on/off.
If you're using a portable like I am, be sure to remove the batteries and set the internal switch to normal batteries so it doesn't try to charge what's not there.
08-18-2008, 09:49 AM
A few notes about the RH-96 with the BR330T.
If you haven't tried one, here's a few things you'll notice.
The volume control knob doesn't APPEAR to do anything - but it actually does control the volume. There is nothing on the screen to show the volume levels. If you want to SEE the volume level indicator, press the large silver knob - this will bring up the volume level indicator. Turning the silver knob with this on-screen will also adjust the volume level. If you PRESS the volume control knob, it will adjust the backlight level of the display. I have not yet tested having the backlight come on when transmission is received - guess I should give that a shot sometime soon!
Just as with the volume control knob, the squelch knob also appears to do nothing - but it DOES actually change the squelch level. Turning it to the far left lowers the squelch level, allowing in the "White noise" if set too low. Turning it to the right adjusts the required signal strength for the squelch to be "broken". If you PRESS the squelch control knob, the radio goes into hold just as if you pressed the Function button on the side of the handheld, allowing you to select groups. This is actually a step up from the button on the handheld, as it stays "pressed" on the remote head until you press it again to turn off the Function button. On the handheld, it would timeout after a few seconds.
Reason: Typos
HTML code is On
