| Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. |
09-02-2008, 08:26 PM
My one scanner and weather radio shack... suggestions anyone?
Ok, I figured that even I have one scanner, you guys can help in giving me scanner suggestions and even setup suggestions.
ok, My scanner:
Uniden BC92XLT, got it at my local Farm and Fleet store, it was a experiment and it turned me to loving scanning! The Attenna is a Radio Shack Telescoping attenna, which is nice, it is better than the stock, but it depends...
 (sorry, don't know what happened...)
Weather Radio:
Since I'm a spotter, of course I have to have a radio. My scanner does not have SAME on it, but I either hear it via Ham Radio or from this radio.
your scanner/setup suggestions are welcome!
Scott
Community Emergency Response Team Member
NWS Severe weather spotter (skywarn)
(*note: any posts I make is made on my own, not for the department that I volunteer For!)
09-02-2008, 08:30 PM
nice...?
09-02-2008, 08:31 PM
Nice antenna on the scanner! looks huge on that scanner!
Depending on the way you are, these might be the last pics that are simple and clean, if you know what I mean, in the future you get more scanners..lol
09-02-2008, 08:43 PM
I know, it works that is what counts, and there is a little more to that attenna that is not in the pic!!! I know what you mean... and cords are a mess already there.....
Scott
09-02-2008, 09:31 PM
More Bearcat scanners..LOL...
RESCUE4NFD
Mike in Garland,Tx.
www.Careflite.org
09-02-2008, 09:44 PM
nice,easy scanner to program and use.everybody's got to start somewhere.save up your money = new toy's.
09-02-2008, 09:46 PM
put up a map of your county, makes you look official
if you want suggestions, look at getting a antenna for external ..if 150 is what your listening to primary get a tuned antenna outdoors or put a wire to adapt the scanner take the stress off the radio BNC to keep it happy for years to come.
K7MHI
09-02-2008, 10:28 PM
I would start off by getting a tripod for the camera.
09-03-2008, 02:25 AM
Either that or switch to decaf. Nice shack dude.
09-03-2008, 03:38 PM
Nice start.
You will get better reception if you shorten that antenna.
Your scanner shows a frequency of 158.239 and for that you frequency range (138 - 174 MHz) only the top 4 sections should be extended.
Marshall - W4MKH
ARES AEC, St. Johns Cty. Fl.
Icom: 718, 2200H, V82
Yaesu: FT-920, VX-170, FT2200
RS: Pro-97
09-03-2008, 04:04 PM
Originally Posted by mkh
Nice start.
158.235 actually..... thanks for all the comments/suggestions!
Scott
09-03-2008, 04:14 PM
If you don't have the instructions -
25 - 136 MHz - Extend all Nine Sections
138 - 174 MHz - Extend only the top four sections
220 - 1296 MHz - Xxtend only 1 to 3 lower sections
Marshall - W4MKH
RS: Pro-97
09-03-2008, 04:17 PM
i have them, but it seems to work fine the way i have it, but i'll try the what the instructions say sometime... Thanks mkh
Scott
09-03-2008, 04:26 PM
deso it say that in the manual? i thought VHF was 19''
09-03-2008, 04:30 PM
Its a start, one leg at a time..............
09-03-2008, 05:01 PM
That would be the correct length for a 1/4 wave but you have to consider the coil which changes that.
If you are transmitting on it then things change some
Marshall - W4MKH
RS: Pro-97
09-05-2008, 12:22 PM
Looks good.
The Union needs to be on the left.
09-05-2008, 12:54 PM
Curious
What is the model of Weather (WX) Radio?
"Santa Must Be Polish" By Bobby Vinton.
09-06-2008, 05:41 PM
www.radioshack.com
Desktop Weather Radio with Alarm Clock and SAME Operation
Model: 12-262
Catalog #: 12-262
Scott
09-08-2008, 01:34 AM
I find that the coil is activated when the bottom of the top sections is pulled out. I use mine as a dual band by using the top four and one or two of the bottom pulled out. The bottom sections pulled out or not makes no difference on VHF that i can tell. But pulling all 5 sections of the top cuts off the VHF-HI performance and sets it for VHF-lo. I've used that antenna since the 90's untill a few years back after getting flexible whip antennas.
HTML code is On
