newsphotog rig
newsphotog
Des Moines, IA
Here is my current setup that was installed last Wednesday (October 29). It's installed in a 2004 Impala.
- Gamber Johnson ShortStack (part #GJ-SM212)
- Uniden Bearcat BCT15 scanner
- Yaesu FT-7800M 2m/70cm transceiver
- Tripp-Lite 375-watt power inverter mounted under the seat
- Larsen tri-band antenna (scanner)
- Diamond NR72BNMO dualband antenna (transceiver)
Don't give me any grief about the trunk lip mounts... I chose them because I want to be able to easily rearrange the antenna setup as I see fit in case I need to add more antennas in the future and I didn't want to be stuck to certain holes in the trunk.
The Diamond antenna is on the left in the picture and the Larsen is on the right.
Station51
Riverside County, CA
Nice install! I agree about the lack of NMO mounts, but these days it seems that everything is going trunked anyway! :( NMO really made the difference with Low band and VHF!
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
It doesn't matter what other people say; If it does it for you, and you're happy with the install, that's all that matters.
K
kb0nly
Guest
Nice clean install, well done! I don't care what you have for antennas or radios, when you tidy up the wiring like that, put some split loom on it, thats what always catches my attention first. I'm picky when it comes to stuff like that, a few minutes and a little extra attention makes it look NICE!
I was going to mention that too, 7800 is a dual band, but i got beat to it by Manny.
I was also going to ask the other question already asked, how well does the trunk open with them on the front edge like that?
newsphotog
Des Moines, IA
Yeah, I don't know why I put it as a 2-meter. Either because I have been pondering a purchase of a new 2-meter radio or because all I use is 2-meter.
The trunk fully opens with no problems. Luckily the Impala has a pretty good slope to the back window. The antennas almost touch the glass, but not quite. I'm going to try to get out before work today and get a picture of the trunk open for you guys.
Navycop
virginia beach, va
The trunk fully opens with no problems. Luckily the Impala has a pretty good slope to the back window. QUOTE]
Can you put these on a pickup truck? Say the hood? I have a Tacoma and don't want any holes. I know what you're thinking -GO FOR IT AND MAKE HOLES>
Navycop
virginia beach, va
[QUOTE The trunk fully opens with no problems. Luckily the Impala has a pretty good slope to the back window. QUOTE]
ShawnInPaso
Really nice setup.
Question; can you tell me who makes the bracket the radios are bolted to??
Tnx.
