Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 08-28-2009, 04:43 PM
Default Infiniti FX45 setup..
This is my Infiniti FX45 radio / computer install.
I have 3 Astro Spectras all with A9 heads. One for VHF, UHF, and 800. They are programmed with local ham repeaters, including the W8DIG P25 machine here in C-BUS. The 800 radio has conventional PS frequencies.
There is a BCD996T scanner in the rear cargo area which is controlled remotely via Freescan software on the Toughbook.
I also have a Cobra model 75WX, 11 meter radio with the W3 control head :-)
Right now my antennas are all mag mount :-(, I haven't decided if I am going to drill yet or not. The antennas are Larsen for VHF, UHF, and 11 meters, and a Maxrad 1/4 VHF for the scanner along with a Maxrad PCS antenna for my mobile internet connection.
I use a Sierra 598U into a Cradlepoint CTR350 router. The Maxrad antenna goes directly into the Sierra 598's RF connector. I achieve between 1 and 2 MB's download easy from just about anywhere in town even while driving. The toughbook is connected to the cars stereo input so I can listen to streaming radio, music etc while driving.
73's and thanks for looking!
Matt, WY8E
Matt
Old 08-28-2009, 04:49 PM
I really like your antenna 'park' on the roof
Own a rig? Write a review on RigReference.com | Ham Radio Equipment
Old 08-28-2009, 04:51 PM
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
If you do drill, space the ants for safety/overload prevention. One good idea may be do NMO hood lip mounts for two, and the rest NMO hole mounted on the roof, two rear, far left/right, one front center, or middle center. I know there isn't a lot of space rooftop to work with. Nice job thus far, not to clustered, and clean wiring!
Admin for AR, LA, MS, and TN
*RS PRO-96, RS PRO-92B, BC855XLT*
"Did I say something funny meow?"
"If a tree falls, do the squirrels get FEMA trailers?"
Old 08-28-2009, 05:03 PM
Brave man you are. Very tastefully done. The Spectras often make the best remote radio installs for anything situation (just about). Nice sneaking in the CB radio. Well done. I like it. No need to drill holes really. I would consider hatch mounts which make come up just as tasteful if not more so. I love hatch mounts (like the comet and diamond models) and they work great for funny angles as they are fully adjustable on more than one axis, of course that may eliminate two of your antennas, so you may want to pick your largest ones).
"Frankly, my dear, I don't give a damn..."
~Gone With the Wind
Terrell
"Ham radio is one of the few slices of insanity that you actually have to test into..."
Thanks MILF. I have been pondering where to put the antennas if I drill. Your ideas are very good! Spacing is tough on this vehicle like you mentioned.
Matt
Matt
Old 08-28-2009, 05:55 PM
creeperjeep's Avatar
Lexan?
-matt
Old 08-28-2009, 06:32 PM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
What is the software on the laptop in the photo?
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 08-28-2009, 07:06 PM
Lexan it is!
The software on the screen is Storm Predator, Freescan, and a streaming media window from a radio station in Berlin.
Matt
Old 08-28-2009, 07:44 PM
IceBlueEyes579's Avatar
Smile
How good is your Cobra CB model 75WX?
Andrew
Old 08-28-2009, 10:20 PM
Hi Andrew,
The Cobra 75 works about as well as one would expect. It's certainly not the most sensitive CB radio out there, but the audio from the little speaker is really loud and it has cool features like scan, wx, and a noise filter that Cobra calls "Sound Tacker"
The bad is that you can very easily change the channel while trying to hit the PTT, and the buttons on the front are easily pushed unintentionally.
Matt
Matt
Old 08-29-2009, 12:45 AM
1150RT-P's Avatar
Nice .... not the most common vehicle you see stuff installed in. Looks clean.
Old 08-29-2009, 02:13 AM
newsphotog's Avatar
You are ready for a night out on the town for sure... good job Matt. Pretty dang impressive
Old 08-29-2009, 04:49 AM
MarkEagleUSA's Avatar
Nice install in a nice ride!
Can you tell me what kind of mount is used for the Toughbook? Is it flexible as it appears?
BCD396T · BC246T · BC92XLT
Old 08-29-2009, 10:45 AM
Mark,
The mount is a RAM POD I with the Tough Tray II. It is very flexible and its on a 1.5" ball so it can be moved 360 deg.
Matt
Matt
Old 08-29-2009, 03:16 PM
What's the diameter of the POD and how rigid is it? Does it flex much while driving with the weight of the Toughbook?
Old 08-29-2009, 08:41 PM
RodStrong's Avatar
Great looking setup. I would try to put the CB where I can see the display, or get to it quickly in the event I am scanning with it and it lands on a channel. You may not use the CB much however, or you may never put it in scan mode. Also, if you put it on the dash somewhere like the Spectra mics, you would probably be less likely to accidentally bang buttons on it while picking it up. Although it's in a nice spot, it's not in a great spot for grabbing it while driving. I'm sure you know that model can use a common variety external speaker, and if you want to get louder audio, I would recommend this. As you stated, the internal speaker is decent, but it much better with an external speaker.
One other thing, be careful with the toughbook being open while driving down the road. You already have lots of distractions in the cockpit of that rig, and looking at the internet or playing with your scanner on the laptop while driving down the road is dangerous. I know.....I have had a laptop and probably twice as much radio equipment as you do in my work vehicles for a upwards of a decade. Just a friendly warning. It also may be illegal in your area to have the laptop open while driving down the road.....you might want to check with your local authorities. Your laptop also appears to be mounted too high.....maybe due to the stick shift. If it can be lowered at all, every inch helps increase your safety. You might think having the laptop closer to eye level is safer for you, but actually, you don't want anything in front of you at eye level, as it potentially blocks your vision of passenger side mirror, the front passenger bumper area, and some other places.
Great job.
Old 08-30-2009, 07:36 PM
everything looks great.
Old 08-31-2009, 09:04 AM
SOFA_KING's Avatar
Wowza! I like this setup. Super clean and very neat. All you need to add to that Spectra stack is a nice LOW BAND Syntor X9000. Then you will have the complete package!
Very nice!
I like the Toughbook too.
Phil
PS - Where did you hide the speakers?
Old 08-31-2009, 01:40 PM
Hi all!
Here are some answers to the questions:
The Ram mount is too flexible for the Toughbook. It does work but with a little too much flex. Ram makes another mount that has 3 legs buts it's obnoxious as hell. I am working on a solution. I have already lowered the mount a little which helped some. I will post when I have a good answer. The mount is not so bad thats its dangerous, but it's ideal for a smaller lighter computer.
The speakers are on the floor behind the seats. It the only place I could find for them!
Thanks for all the nice comments!
Matt
Matt
Old 09-06-2009, 05:19 PM
FD5722's Avatar
Send a message via AIM to FD5722 Send a message via Yahoo to FD5722
I don't comment on to many installs, but I must say Kudos to you on this one. Those A9 heads look great in there, along with the Toughbook. A+++++
Daniel - Nextel 151*477*10041
Moto MTS2000 Mod2 - VHF, Moto Syntor 800 Type II
Moto XTS2500 Mod 3 - 700/800
"You can out run the motor, but you can't out run the Motorola"
HTML code is On
Similar Threads
Modest "Digital" Mobile Setup SOFA_KING Pictures Of Your Shack/Mobile Setup 13 08-30-2009 11:08 AM
FS: Complete Motorola Ham Setup kd0ezq Old Classifieds Archives 6 08-17-2009 11:48 PM
Critique Wanted - My SWL Antenna Setup blantonl Antennas and Coax Forum 5 06-16-2008 03:45 PM
PAPD setup help noahyc New Jersey Radio Discussion Forum 10 03-25-2007 02:56 PM
Best setup of channels for Denver?? brianmacho Colorado Radio Discussion Forum 11 05-19-2005 07:36 PM
