Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 09-22-2009, 11:32 PM
smokeeater861's Avatar
Default Simple Mobile Setup ('96 Jeep Cherokee)
This is a simple setup that my friend introduced me to. It's a 3/4" NMO mount with a BNC connector at the end that gets hooked into my Motorola GP340 (HT750). It's temporary until I get mobiles. This is mostly used for scanning some local UHF public safety channels and the rest consists of 440 Ham frequencies.
Comments are encouraged, other than that I need to wash/clean my vehicle, that's a given!
Tyler Supplee; KB3THS
Firefighter/First Responder
Motorola Maratrac on 2 meters (144-174), Motorola HT750 (403-470), Uniden BC-350C mainly on Low band (30-54) and Realistic PRO 2020 scanner.
Last edited by smokeeater861; 09-22-2009 at 11:35 PM.. Reason: Rearrange Pictures.
Old 09-23-2009, 12:28 AM
RodStrong's Avatar
I have a Cherokee similar to that, with a dual band (UHF/VHF) 8800r remote mount head mounted above my steering wheel, along the flat bottom of the dash frame. It fits on there good, and only obstructs the tripometer, which I don't really use anyway. And since it's above the steering wheel, you can easily drive and look at/manipulate the radio head with very little effort and in a much safer manner than looking down further to more traditional radio mount locations. Just a suggestion.
Old 09-23-2009, 12:35 AM
Get the coax out of the door frame. Its easy to get that trim out and run it behind it. Your going to pinch that off and break the cable.
Old 09-23-2009, 09:27 AM
The weather seal closes around it and I can stick my pinky in between the door and dash and feel a small gap between the coax. I am thinking about rerouting it straight down and let a little of the coax be exposed up toward the corner of the dash instead of there, but thanks for the suggestion!
Rodstrong, I have an HT without a display and only 16 channels, so I can manipulate the radio easily. I'll keep that in mind though when I do decide to get a true mobile setup with a remote head. Most likely though, I'll get a Mobile with a Full DTMF mic on it and usually they come with a channel up and down button on them, its just a matter of glancing over at the display to confirm the channel your on.
HTML code is On
