Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 10-31-2009, 01:26 PM
Default Pontiac G8 - Update
Made some changes over the summer and thought I'd post some updated pictures.
Running a Yaesu FT-8900 now. My club recently put a 6m repeater on the air and I wanted to be able to play a bit. Since console space is tight and my Kenwood 90 Series head can only control two and not three drawers, I lamented and swapped in the 8900.
The control head is in the same place as before, just not as big. I was able to tuck a small speaker in behind. The audio seems fine to me.
The drawer is in the trunk. Power comes from the same place as before. Gotta love having the battery back there!
Antennas consist of a Larsen NMO50 for 6m and NMO430CS for 70cm. Since the 8900 has only one antenna jack a diplexer sends UHF to the shorter antenna and low-band to the longer one behind it. The mount in the middle is unused at the moment (hence the rain cap) but I might put a GPS antenna on it.
I do have a Larsen NMO270SH I may swap with the UHF one so I can have 2m again. I did play around with a NMO150 for 6m and 2m but the whip was too long and I found it kept hitting everything.
And here's the whole package. Astute readers will notice the wheels are different. The car is sporting Bridgestone Blizzaks on aftermarket rims now. Winter is just around the corner!
Old 10-31-2009, 01:31 PM
Astrak's Avatar
Nice install and sweet car.
Maricopa county law enforcement feed
Old 10-31-2009, 03:30 PM
FD5722's Avatar
Send a message via AIM to FD5722 Send a message via Yahoo to FD5722
Good lookin install.
Daniel - Nextel 151*477*10041
Moto MTS2000 Mod2 - VHF, Moto Syntor 800 Type II
Moto XTS2500 Mod 3 - 700/800
"You can out run the motor, but you can't out run the Motorola"
Old 10-31-2009, 05:02 PM
real nice and clean.
KC9QHR
Plainfield, IL
Old 10-31-2009, 05:52 PM
ScanManQSL's Avatar
Nice install!!!
-Ben-
A Proud Radioreference Junkie Since June 2ии3
Certified LWX SKYWARN Spotter: MOS124
"I am just running a few watts, opps there goes the circuit breaker."
Old 10-31-2009, 07:38 PM
b7spectra's Avatar
Very nice! What type head unit do you have?
/\/\|k.e
WQKM383
Support Your Local Search & Rescue Team - - - Get Lost!
Old 10-31-2009, 07:49 PM
Thanks all for the comments.
"What type head unit do you have?" Before was a Kenwood TK-790/890 dual-band tied to a KCH-11 full-featured head. I also have a TK-690 to play on 6m. But to install it would require a second head and space is at a premium.
All of that gear now sees new duty in the home shack where space isn't an issue!
Even though I highly doubt I'll ever use 10m the best solution I found for the car was going with the Yaesu.
Old 10-31-2009, 07:50 PM
burner781's Avatar
Wow. Very nice.
Using an Icom R5
Motorola Sabre IE
BC895XLT
BC890XLT
BCT15
BCD396T
BCD996T
BC200 XLT
Old 11-01-2009, 05:06 AM
Steering wheel is on the wrong side :S
http://www.aurfscan.com.au - Australia's premier radio communications monitoring forum
Old 11-01-2009, 08:23 AM
Exactly, but it is atleast half way to being acceptable being a Holden VE Commodore!
Old 11-01-2009, 09:24 AM
K9WSS's Avatar
Send a message via AIM to K9WSS Send a message via Yahoo to K9WSS
Default Drilled NMO Mount's
A++ for drilling those mount's. Excellent install; nice and tight. Thanks for all the pics! Now, how 'bout some of the home 'shack?
Will Sperling, K9WSS
k9wss.1@gmail.com
DuPage County, IL USA
Old 11-01-2009, 09:27 AM
MPSCS's Avatar
Pontiac G8...they won't make them like that anymore.
Old 11-01-2009, 09:29 AM
Nice work.. I would have spaced the antennas across the trunk rather than in a row . Other than that its good
Old 11-01-2009, 09:30 AM
Very nice install!
How much snow can the G8 handle with the Blizzaks?
GTO_04
Old 11-01-2009, 10:16 AM
firetaz834's Avatar
Nice install and sweet vehicle. After reading the comments about how nice the G8 looks it reminded of an article I had read about the G8 now going to be used in law enforcement (it will be interesting to see how they handle the mounting of the equipment). So, here is a link and it will be worth waiting to see how those turn out.
2011 Chevrolet Caprice - Pontiac G8 lives on as police car: Consumer Reports Cars Blog
Old 11-01-2009, 02:42 PM
very nice install looks pro!
GRE PSR-600--- > http://www.radioreference.com/apps/audio/?ctid=2408
Uniden BC895XLT --- >
RS PRO-96
RS PRO-106
RS PRO-93
Fire Fighter I/II
Old 11-01-2009, 06:26 PM
llllllllll's Avatar
nice install
Old 11-01-2009, 09:53 PM
Thanks. I had thought of that but felt it might have detracted from the overall look of the car. Yes, I'm a little vain that way!
Besides, the OPP and MTO Impalas around here have a narrower trunklid and they run two antennas (UHF for the VR and wideband VHF for actual comms) in a north-south configuration and I figured if it works for them it'll work for me. The actual spacing is about 8". Haven't had any interference problems.
On my past vehicles I've mounted one antenna on the roof and the other on the trunk. But with the G8 the AM/FM/XM/OnStar is on the roof and I didn't want to mess around with that.
@GTO_04: This is the first winter for my G8 so we'll see how it handles in the snow. Other owners have said it does just fine mostly because of the 50/50 weight distribution. I know the OE Goodyear Eagle RS-A's suck in snow. The Blizzaks come highly rated.
Old 11-10-2009, 03:04 PM
Yes, that is rather vain. However, I don't see the wide spacing as looking much different. Style over substance! Fashion over form! Since you are running a duplexer the spacing isn't that important anyway, only one antenna is working when the PTT is pushed.
When you wrote "diplexer" I assumed you meant "duplexer." Do I assume correctly or is there device called a diplexer? I'm working on hooking up a HF/6m antenna and a 2m/70cm antenna to a base radio that has separate jacks for HF, 6m, 2m, and 70cm. I'm going to have to split the cables from the two antennas into four jumpers to connect to the radio. This is just the opposite of your situation, but would I need to use diplexers or duplexers to accomplish this?
The picture of the radio installation appears upside down, or is the unit installed on the trunk lid? I must be missing something here as no matter how I turn the screen around on my laptop I can't figure our how you mounted it. I've never heard of the radio being referred to as a "drawer" either. I've always heard techs just refer to the control head and the radio.
Old 11-10-2009, 08:23 PM
izzyj4's Avatar
Originally Posted by Exsmokey View Post
......The picture of the radio installation appears upside down, or is the unit installed on the trunk lid? I must be missing something here as no matter how I turn the screen around on my laptop I can't figure our how you mounted it.......
If you look behind where the radio is mounted, you will see the rear deck speaker for the AM / FM radio. It is mounted hanging from the metal of the rear deck in the truck. I can see where you might think it is upside down by the way its mounted but the picture is correct. Though I point this out to ya.
| BCD396T | BCD996T | BC780XLT | PRO 2006 | PRO 2046 | BC560XLT | BC780XLT w/ Scanner Master remote head kit | TRS-452 | TRS-453 |
HTML code is On
