Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 11-01-2009, 12:47 PM
Default My Tundra setup
Here is my setup- I have been lurking on this section looking around for so long that i figured I would post some pics-- I work for an Install company here in Dallas- and use my truck to show off our computer mounting equipment--<-------READ WHACKER POLICE
Anyway- the equipment is----
Gamber Johnson base, pole, upper, cf29 pandock no rf,
Panasonic CF-29 with aircard
Icom 2720 with aprs on the right side
Tiny trak 3 for aprs interface-
3x garmin gps 18 (2 serial, 1 usb)
Uniden Bct 15 with GPS
Antennas-
Maxrad 800 mhz for the scanner
Dual band Austin 500c
No name dual band that i had for an icom 2100 that died on me
Old 11-01-2009, 06:19 PM
Laptop displaying APRS data?
Pretty slick install. I'd love a console that wide.
Old 11-01-2009, 06:28 PM
llllllllll's Avatar
wow very nice
Old 11-01-2009, 06:58 PM
Yes- i usually have an aprs screen up-- i usually just use aprs.fi- but am trying to use uiview instead- just cant figure it out--
Amateur call---WA5DKW
Old 11-01-2009, 07:33 PM
burner781's Avatar
Very cool.
Using an Icom R5
Motorola Sabre IE
BC895XLT
BC890XLT
BCT15
BCD396T
BCD996T
BC200 XLT
Old 11-02-2009, 12:45 AM
Neat, I've been looking into figuring out an APRS setup, I think it'd be the coolest thing to know when I'm passing by another ham on the road. I know I'm a bit of a geek
Old 11-02-2009, 06:14 AM
W9RXR's Avatar
...but am trying to use uiview instead- just cant figure it out--
This is a separate discussion, but I'm a big fan of UI-View. I've tried APRSpoint, WinAPRS, and Xastir, but I came back to UI-View. With Precision Mapping and the PMAP server installed, UI-View has zoomable, scrollable maps with reasonably current map data and it has most all of the APRS features like messaging, objects, digipeating, etc. I have an old IBM ThinkPad T23 running Windows XP and UI-View that is pretty reliable. I use an Argent Data T2-135 as my tracker which I put into KISS mode to interface with UI-View. The T2-135 is connected to the laptop via the DB-9 RS-232 port on the laptop. I also have a Garmin 276C that is connected to the laptop via an RS-232 to USB converter so that UI-View can get position data. It all seems to work pretty well for me.
Old 11-02-2009, 06:17 AM
W9RXR's Avatar
If you don't want to carry a laptop computer in your vehicle, you can go with an Argent Data OT2 or T2-135 tracker (Tracker2 | Argent Data Systems) connected to a Garmin nuvi 350 GPS unit. The Garmin will display waypoints of APRS stations near you based on beacons received by the tracker. Or go with a Kenwood TM-D710. It can generate waypoints that it can feed back to a Garmin mapping GPS unit.
Old 11-02-2009, 10:11 AM
I have heard of using a regular garmin to get data to an interface- but i did not know it went both ways and actually plotted other users- this would be neat to play around with-- do you know if it is compatible with any nuvi unit?- i have a garmin nuvi 205- i might want to check this out-- thanks----
Old 11-02-2009, 12:32 PM
W9RXR's Avatar
This feature in the Argent Data Tracker2 series works with the Garmin Fleet Management Interface. Here's a link to the wiki on Argent Data's web site that talks about FMI:
Garmin FMI - ArgentWiki
Old 11-18-2009, 03:45 AM
torrespi's Avatar
Nice install and set up ..much respect !
73's
Salvadore Torres
WOSCT
Colorado
Old 11-18-2009, 03:47 AM
torrespi's Avatar
By the way ...I just brought a Austin 599C soft tip ........how do you like yours and any feed back would be nice !
Salvadore Torres
WOSCT
Colorado
Old 11-18-2009, 08:46 AM
hoser147's Avatar
Very nice setup!
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 11-18-2009, 04:55 PM
hippieman556's Avatar
nice looking setup
Old 11-19-2009, 02:56 AM
SouthSideScannerGuy's Avatar
Looks good!!
KC9NTO
| BC346XT | PRO 92 | PRO 94 | PRO 106 | PRO 137 | PRO 160 | FT2800M | FD150A | KA1102 |
My Listening Post
Old 11-19-2009, 08:00 AM
Nice set up.
Which one is the short black round snub antenna and whats it used for?
Old 11-19-2009, 05:19 PM
W3MOT's Avatar
Is that a Ram Mount?
Believe half of what you see, and none of what you hear.
Old 11-20-2009, 07:20 AM
W3MOT's Avatar
lol. I should read alittle slower next time
Old 11-20-2009, 02:18 PM
The austin antenna works great and is flexible enough to take some abuse from parking garages and low overhangs-- performance is pretty good- i can hit the dallas 2 meter repeater from here in mckinney at full strength- (about 30 miles or so)--
Old 11-20-2009, 02:19 PM
Originally Posted by K1MIZ View Post
Nice set up.
The short antenna is a maxrad 800nhz+ antenna- i have it hooked up to the uniden bct15 scanner- works great!!!- i can pick up dallas pd/fd from 30 miles away- they are running uhf also-- trunked is pretty good- but really only effective for the county you are in---
HTML code is On
