Mobile Install pictures by jamesfabiano - Photobucket
Hey all..
Finally got my pro 197 in my car. I was originally going to get a transmission hump mount, but figured this worked better, and saved me $90!
I took the console apart and drilled three holes for the scanner into the outside of the inside part of the console. I wanted to keep all the screws and wires hidden as much as possible, so this was a way to do that. I then drilled a hole in the inside-bottom of the console to thread all the wiring through. After that I moved the coax under the passenger seat and through the hole in the console. I ran the power cable from where the cup holders would normally go, down to the driver side floorboard, under the driver's seat, through the hole in the console, and into the scanner. Then I drilled the holes and installed the Moto speaker. Thanks to NeFire242 for that speaker.
I would have liked to have drilled the holes lower so the scanner didn't stick out as much, and also hide the wires coming from the 12v plug, but other than that I'm really happy with how this install went
Any feedback/suggestions welcome! Thanks for looking!
See all pics here:
