Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
  #61 (permalink)
Old 11-14-2012, 8:56 PM
kma371's Avatar
Originally Posted by ZOU4Life View Post
Did you get it mounted? I have a 2012 Chevy Cruze and about the same Uniden scanner and have no idea where to put it. If you take the center compartment on the dash out, it will mount and look better I think. I'm just worried about someone breaking in and stealing it since it's so out in the open.
Pics are in the thread
  #62 (permalink)
Old 11-14-2012, 9:29 PM
KD2DLL's Avatar
Looks nice. Nice and clean.
Alex Kaczor--- feed@kaczortech.com
Check out my new ham website kd2dll.com
With a scanning forum as well! forums.kd2dll.com
  #63 (permalink)
Old 11-15-2012, 8:05 AM
gr8rcall's Avatar
Originally Posted by SignalSeeker View Post
I think I would try and get a RH-96. They are very pricey but would make your instal much easier.
I have a BCt15 I was trying to figure out how to mount. My wife said no to all the drilling and cutting of the dash since it was a new car. So I showed her and bought a HomePatrol. Installed nice and clean with no complaints from the MRS except the price.
Justin
Ha-Ha!
Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
  #64 (permalink)
Old 11-26-2012, 10:07 AM
How are you guys powering your equipment? I have a 2012 Cruze which I think is the same as the 2011. Anyway it has a fuse block under the steering wheel, on the left. Would that be the best place to get power and ground from?
  #65 (permalink)
Old 11-26-2012, 3:38 PM
kma371 i went to the right side of my similar 2011 Malibu with a LIDO Mount and the adhesive pad but the 3M adhesive pad itself was a problem during the very hot days of the summer so i had to use some self taping screws and i don't mind the look - does not bother me. This is an Icom IC-900A control head, pic 1 was before screws added.
fineshot1
NJ USA
  #66 (permalink)
Old 12-03-2012, 4:40 PM
Originally Posted by kma371 View Post
Yea I cut out some of the back, got it to fit.
I'm probably going to mount it in the glove box like you did. You just cut out the back? Did you screw in the scanner to the bottom of the glove box? Did you wire a speaker out to your scanner? Thanks!
  #67 (permalink)
Old 12-03-2012, 6:05 PM
kma371's Avatar
Yeah I had to cut out the back or it wouldn't fit (couldn't close the glove box).
My Cruze has a ext speaker jack plug in the center armrest. So I just ran a 1/8 stereo plug behind the glove box to the armrest.
  #68 (permalink)
Old 12-03-2012, 6:06 PM
kma371's Avatar
Looks good. Too visible for me though
  #69 (permalink)
Old 12-03-2012, 7:08 PM
There are not many options on these new vehicles so that was just about the only
option i had with the icom IC-900A and ID-800H radios i have and when i leave the
car after parking it a hat is draped over the 900A control head and is covered up and not
visible. The hat also serves to remove the head from the direct sun light and keep it cooler than
having it in the sun. The band stack for the 900A is in the trunk.
fineshot1
NJ USA
  #70 (permalink)
Old 12-03-2012, 8:09 PM
What kind of coax cable & connector did you run from your scanner to antenna?
  #71 (permalink)
Old 12-03-2012, 9:15 PM
kma371's Avatar
Whatever came with the antenna. I don't recall off hand what type of cable it is.
  #72 (permalink)
Old 12-04-2012, 4:30 PM
How did you hook up the power cable?
  #73 (permalink)
Old 12-04-2012, 4:53 PM
Center of the dash is the best place you dont have to take your eyes off the road that much.And when you park for a long time put it under the seat.
  #74 (permalink)
Old 12-04-2012, 6:09 PM
kma371's Avatar
Fuse box
  #75 (permalink)
Old 12-04-2012, 6:11 PM
kma371's Avatar
Not really. As someone pointed out if you get into an accident it will come flying at y your head.
  #76 (permalink)
Old 02-03-2013, 6:38 AM
sonticus's Avatar
Like the setup, but I'm curious about the antenna mount. Does it allow you to quickly tilt the antenna down if you need to?
I'm looking at getting a similar one to mount on my luggage rack but I want to be able to tilt it down in a hurry if I'm driving into a parking garage or something similar.
Also, are you still satisfied with the Maldol?
- R
  #77 (permalink)
Old 02-03-2013, 5:19 PM
kma371's Avatar
Default Re: 2011 Chevy Cruze
yes. the antenna folds down as long as you loosen the screw. or you can just unscrew the antenna and put on the cap.
the antenna receives very well on UHF and VHF not so much lo band
HTML code is On
