| Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. |
04-09-2012, 9:43 PM
Originally Posted by 03msc
Pulaski, yeah. That's strange...I admit I haven't tried to monitor them from home (hour and a half away) but maybe their system is statewide? I see they aren't in the AWIN system but I guess they could have sites outside PulCo or something. Maybe someone else will chime in (or you can post up in the Arkansas threads and see if someone knows if you're interested).
I would have thought that but the radio was nearly silent till I got about 20 miles of of Memphis. Same on the way to LR as well. I don't know if I could have received Memphis PD channels in the LR area since I turned them off once I was out of their area.
04-09-2012, 10:20 PM
B-
Is that the 10" console by Havis?
04-09-2012, 10:27 PM
Originally Posted by doublem
B-
I am not sure of the length. I will measure it tomorrow.
04-18-2012, 8:22 AM
Sorry I haven't gotten measurements on the console yet. I think it is a 10"
I picked up a Pelican 1650 case to put in the Tahoe. I plan to put jumper cables, tool kit, tire repair stuff, first aid gear, road flares, etc in it. I have to figure out a way to attach it inside there. I am considering drilling holes in the case and floor and bolt it to the floor. I am going to try to find another option first because I dont want to destroy the water tight case if I dont have to incase I decide I want to take it out to use as dry storage else where. We'll see when it gets here what I can come up with.
04-18-2012, 5:54 PM
I wouldn't drill in it.... If you could put hooks in it, and still make it waterproof, I'd do that.
Take a picture of the back so we can see possible mounting spaces....
Later,
 ~ScannaMan9~
Scanning with: Pro-2052, Pro-107, live feeds, and a BCT15X to come
Also using apps on: iPhone4S, and iPod touch (4G)
04-18-2012, 6:20 PM
I'd get some screw in D-rings or cargo hooks small/medium size like you find in the Jeep Grand Cherokee and either bungee or nylon strap it in. If I can find the part number for the hooks I'll post it
04-18-2012, 6:37 PM
This is the space I am working with. I want to put it towards the passenger side. I am thinking have it with the back against the side though I am not sure of how large the case is. I know the dimensions but that is hard to picture how much room it will truly take up. My wife is an engineer and welder so that gives me other options, I want to be able to open it without unhooking it. We are considering building a frame of sorts to bolt to the floor and hook a tie down type strap around to attach the case with. I also plan to have a water jug or two in there so something will be there to secure those as well.
KK4NES
Kenwood TH-D72A - BaoFeng UV-5R Plus - Kenwood TM-281A
Uniden BCD996XT
04-18-2012, 6:49 PM
check out 2 companies for ideas
rotopax.com nice stuff and you may like the setup they have a water storage and storage holder in one
and springtailsolutions.com these guys make custom molle and rack systems for military and police vehicles. you might get some ideas for your rack settup. they sell kits and parts of kits to make your own setup look through the whole site lots of pics
04-18-2012, 11:24 PM
Thanks! If and when you have time. If you don't, no worries! Don't drill your case!!
04-19-2012, 5:27 AM
 ~ScannaMan9~
04-19-2012, 7:58 AM
Originally Posted by ScannaMan9
The page(s) you requested is NOT AVAILABLE
Sometimes there's justice & other times there's just Us!
GRE PSR 800
BC200XLT
BC780XLT
04-19-2012, 8:01 AM
That spring tail thing is awesome but no way am I spending $1600 + on it, lol. I have some 5 gal jerry cans on ebay I am looking at. About $40 shipped each. I am thinking about building a simple rack type thing. Something that will bolt to the floor and run front the rear on the passanger side. Then I can run a strap through it to secure water cans, pelican case, etc to it. That leave room on the other side for luggage for going out of town and leave plenty of room to get to the spare tire tools. The rotopax look great. If I decide not to build a rack I may go that route for water storage.
04-19-2012, 8:28 AM
Hmmmm. Seems like it worked for bnoland below:
If i read it right, you can get just 1 particular section, or you could custom build something similar.
 ~ScannaMan9~
04-19-2012, 8:37 AM
He is right actually. I clicked the link and it didnt work but a quick google search found the same page. Not sure why the link didn't work since it looked the same as the page I was at. Very cool setup but no way I can afford $1600+ for it. I am thinking I may get my wifes welding and metal working skills and put them to use! I can kind of weld.. she did it professionally.
04-23-2012, 2:16 PM
I got a very very little progress done but progress is progress. I ran one of many permanent antenna wires today. No pictures of that. Pretty obvious and doesn't look any different than the it did before. I am very happy with the reception. I was actually picking up Little rock AR pd loud and clear with it. Much better that the telescoping antenna was getting. I also mounted two whelen 500 series TIR 6 on the back. The Tahoe was previously a police vehicle and had holes already from the department it came having the same lights there. I hated that hacked look with the holes. I got them in clear and will eventually tie them into the reverse lights for more rear lighting when backing. I may tie them into a switch as well for rear lighting if the need beer possibly into a flasher unit if I decide to continue security work. It is a slow process but is coming along. I hope to have a lap top stand soon.
KK4NES
Uniden BCD996XT
04-23-2012, 2:29 PM
Is it just me, or is that tag expired? (As of 7/10)
I don't live there, though so it may still be registered.
Good Idea's for lighting.
 ~ScannaMan9~
04-23-2012, 2:32 PM
Lol, it's an old tag off of my impreza when I bought it. Just covering my current tag with it, my slight paranoid habit.
04-23-2012, 2:46 PM
A quick vid?
GRE PSR 800
BC200XLT
BC780XLT
04-23-2012, 3:55 PM
Here is a quick video of the outside and inside. Nothing fancy. I have a long way to go still.
Inside
2008 PPV Tahoe - YouTube
outside
2008 PPV Tahoe walk around - YouTube
I will try to get some better video later. I felt like a doof talking to the camera but hopefully I will get a good video together of it later.
Some may notice my OEM radio is back in. I was having issues getting video to play on my Pioneer and there is a mysterious blue line going through the middle all of the sudden so I pulled it out. I think I am going to stick with the OEM.. it looks cleaner in there and I can sell that Pioneer and put it towards more stuff for the tahoe.
04-23-2012, 4:30 PM
Cool, next vid turn'em lights ON!
GRE PSR 800
BC200XLT
BC780XLT
HTML code is On
