| Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. |
03-29-2012, 10:25 PM
2001 Civic RH 96 install for 996xt
Simple, yet effective. Miss my trailblazer though.
“You have the NIFOG – that’s your interoperable communications plan.”
03-30-2012, 9:28 AM
Looks decent enough. How is it mounted? What antenna are you running
Saber, HT1000, BCD396T
03-30-2012, 9:57 AM
I didnt want to go too crazy with wiring direct. I took the car off my wife's hands, traded in my trailblazer so she could get her new CRV. Its a 2001 so wanted to take it easy on the electrical system.
I am using a Scan-Force ( https://www.scannermaster.com/Scan_F.../25-541147.htm) Mobile Mag Mount antenna on the trunk.
Right now I am using the reare seat pocket to house the base 996XT until my remote cable extension and speaker arrives. At that point it will be permanently installed in the trunk or other non-conspicuous location (open to ideas). I wanted to use the glove box and got really excited when the base fit perfectly. That was before attaching any cables. (oh well)
I took the storage tray out from under the stereo controls to see if it would fit, and it is almost perfect. The reomote mounting plate is a little small so there is a gap. But I was able to manipulate the standard bracket to reverse-fit into the mounting harness that holds the AM/FM receiver in place.
Bought a three-way adapter from CellPhone Shack to cover both power supplies and my cell phone charger.
I have some lights that need to go in, but the Civic is tough on my as I am accustomed to working on Chevys.
I have added some pictures, more to come.
03-30-2012, 10:05 AM
I am actually finding YouTube very useful. There were a few videos to show how to get back there in the first place.
03-30-2012, 11:35 PM
Looks alright,how long have you had that mobile antenna?
03-31-2012, 9:58 AM
About 2 years.
03-31-2012, 11:54 PM
Originally Posted by cifd64
About 2 years.
I see,I was wondering why it was that color.
How do you keep rain from running down the coax and into the trunk?
03-31-2012, 11:57 PM
Probably the lighting too. Anyway my birthday is this week and the wife has some stuff on order to finish the job. Pictures to follow.
04-05-2012, 9:39 PM
Here is an update
I decided to dismantle and remount the remote a little more securely. I removed the custom bracket I made because it was just too flimsey and would be easy to take out should the less-honest want it.
Take a look.
Next week I will be moving the base from the back seat to the trunk. Those pictures to come later.
04-06-2012, 10:32 AM
Tiny bit of putty.
04-06-2012, 11:03 AM
Looks Good.
Scanning South West Washington And The Portland Metro Area
04-06-2012, 2:49 PM
Tiny bit of putty.
What kind of putty?
04-07-2012, 11:10 PM
just plumbers putty. Enough to broaden the diameter of the cable so it evens out the pressure on the weather stripping.
04-08-2012, 7:28 AM
Okay,thanks.
04-08-2012, 11:49 AM
Update 4-8-2012
I got the base into the trunk. The Civic doesnt have a lot of places to drill through, so i used a piece of scrap wood and some velcro strips underneath to secure it to the fabric in the back.
I am wondering if the strobe kit is going to create any interference, then again, I dont always use my lights anyway. Take a look. As always, suggestions are welcome.
07-22-2012, 12:33 PM
Would you mind explaining how your powering the scanner in the back? I'm going to be installing a 996xt and rh96 and I am looking for options. The scanner will go under one on the front seats and I want it to be powered when I turn the key off. I'm not really worried about the remote head as I can turn it off myself.
Thanks,
Jason
jasday
PRO 106
Fort Worth Texas
07-22-2012, 1:54 PM
What kind of vehicle?
Does the cigarette lighter(s) shut off when the ignition is off?
You would be better off using the same power source for both, but dont split. I bought a triple-tap adapter for mine and everything shuts off when the ignition is off.
If you want the scanner to stay on (not recommended) you need to find a suitable constant to tap into. Again, depending on the vehicle, the cigarette lighter will do. In my civic, there was little room under the seat, so i ran it from the trunk.
07-22-2012, 3:22 PM
I have a Dodge RAM 1500 with one plug that is only on when the ignition is on. That's where I was planning on going with either the scanner or radio head. Just looking at options and insight from those that have been there. Would it be a possibility to tap into the plug with say the scanner and then plug into it with the remote head? I want a clean look, but what I've been reading on my truck getting into the fuse block is hard if not possible.
jasday
PRO 106
Fort Worth Texas
07-22-2012, 5:04 PM
Well what I was reading was wrong, so what I may be doing is to run the power cable into the engine compartment and find a fuse that is switched on by the ignition for the scanner and run the rh96 to the cigarette plug and tie into that. Now I need to find the relay I saw in another post that is used to plug into the fuse box.
Edit
Well disregard that, all on the fuse slots and relay spots are filled, but I did figure out that two cigarette plugs are only hot when the truck is on, I think I figured out my electricity problem. Now to figure out how to get to them.
jasday
PRO 106
Fort Worth Texas
08-04-2012, 8:09 AM
Looks good but I would get a piece of ABS plastic and fill in the sides ,any car stereo place will have it.
Zippos in belleville used to have for $8.
HTML code is On
