Pictures Of Your Shack/Mobile Setup -
Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
06-27-2012, 7:43 PM
2008 Silverado Shack
My mobile setup:
Icom IC-2820 for FM & D-Star
Kenwood TK-7180 & TK-8180 with Motorola Repeater interface
Motorola Syntor X9000 Low band for 6 Meter Ham band
Acer laptop with Yaesu FT-2600M & KPC3 Plus for APRS operations.
PRO-197 Scanner
Mirage 100 watt UHF amplifier (not pictured)
06-27-2012, 8:01 PM
Looks great..Nice job.
If it's a Motorola keep it...anything else throw it out!!
06-28-2012, 12:37 AM
Great selection of radios. You may want to try 1/4 wave antenna's on the roof.
Also, try some wire management, loomnig wires, hiding them where you can. It's a lot of radios in that small space but I know it can look good if you organize it correctly.
06-28-2012, 5:27 AM
Nice selection of radios. Now you just need to clean up the wires and route them properly.
06-28-2012, 8:02 AM
Quite interesting.
06-28-2012, 5:03 PM
Very Nice.
Scanning South West Washington And The Portland Metro Area
06-28-2012, 5:14 PM
Very nice! That's a cab full of radios. Thanks for sharing with us.
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
06-29-2012, 12:14 AM
Definitely a nice collection! I agree, maybe some 1/4 wave antennas would clean your roof up a tad. NIce setup though.
06-29-2012, 1:50 AM
Originally Posted by KD0LDK
Definitely a nice collection! I agree, maybe some 1/4 wave antennas would clean your roof up a tad. Nice setup though.
I need the gain factor of 5/8 wave antennas, especially on the VHF fire radios as we run simplex in our county, I just need to find the time to clean up the install then it will be better.
06-30-2012, 2:50 AM
Ah ha, well that's understandable then. We only use simplex channels on the fireground, so just about any antenna will do for us in that regard.
07-08-2012, 11:18 PM
interesting that you use a repeater controller i have in car repater with a tk7180 and a uhf gm300 with out, i have a video on youtube check it out
07-09-2012, 2:48 PM
Address of the YouTube video?
Sent from my DROID4 using Tapatalk 2
List of scanners & radios that nobody cares about...
My Feed
Andover VFD
07-10-2012, 1:01 AM
Hamsexy !!!!
07-10-2012, 6:04 AM
I located the YouTube video and the reason why I'm using the repeater controller is because neither the 7180 or 8180 is dedicated to the vehicular repeater purpose, I use both as regular voice radios and have link frequencies that I use on VHF or UHF depending on what I want to cross band into.
My Feed
Andover VFD
07-14-2012, 4:31 PM
So that's what you have packed in that truck; nice setup indeed. I keep meaning to at least grab my portable antennas to put in my trailblazer so I can have them with my go-kit, which currently consists of a handful of HT's, a new IC-2200H and my FT-817 (I don't yet have the UT118 installed in the IC-2200, so it's currently analog only).
07-15-2012, 11:14 AM
i see what you are saying my gm300 in buried in the rear of the car on a single freq, i see you would have total flexability with your way of doing it, i only needed to relay vhf to a uhf ht.
Best 73
07-15-2012, 11:15 AM
07-15-2012, 7:57 PM
whenever you get the chance get the UT118 so you can join us on the KB3WNO-B Dstar repeater in Greenville, PA.
My Feed
Andover VFD
07-17-2012, 9:31 PM
Nice...I miss my Silverado.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Uniden 536 HP Kenwood TS-2000 Comet 250-B Diamond D3000N
07-18-2012, 6:43 PM
I think the IC-2200H will be going in the S-10 to replace the aging Alinco DR-130, though I will put the UT-118 in it anyway. I'm probably going to go with either an IC-2820 or an ID-880 in the Trailblazer, since I'm putting up a 70 cm D-Star Repeater here.
Thread Tools |
Display Modes |
HTML code is On
