Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 09-21-2012, 5:24 PM
bigmattyl's Avatar
Default My Apt Setup
Hey everyone,
Here's my setup
My scanners are as follows:
PRO-92
BC245XLT
PRO-2006
BC780XLT
BC796D
BCD996XT
HP-1 (with the advanced update)
PRO-90 (with Discriminator tap, its hiding to the right of the stack, feeding unitrunker)
I'm in Orange County, CA and renting an apt, so my outdoor antenna options are limited (read: I can't have any) so here's the best i can do.. they do ok, wish i could do better, but i think im getting the best reception i can get given restrictions... however i havent tried any inline amplifiers or the like yet
Pardon the cat furniture.
thanks for taking a look and im always open to suggestions
Matt
Old 09-21-2012, 5:27 PM
hfxChris's Avatar
I like it! Looks great to me
Pro-97 | Pro-137 | Pro-2055 | BCD396XT | BCT15X | BCD996XT | HP-1 | Kenwood R1000 | R820T | Afedri SDR-Net
Old 09-21-2012, 5:36 PM
jtech48's Avatar
Very nice, Great Job!
In Flying, Carelessness And Overconfidence Are Usually Far More Dangerous Than Deliberately Accepted Risks
WQOE503
Old 09-21-2012, 5:43 PM
sadman3's Avatar
very nice
pro197/pro106/396xt
steve
Old 09-21-2012, 5:52 PM
russellmaher's Avatar
Very nice shack in my opinion. Since I too am an apartment dweller, I feel your pain; no outside antenna for me either.
I see a couple of Austin Spectras in the window, right? Damn good antenna (mine's on the car).
Nice shack and thanks for sharing.
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
Old 09-21-2012, 5:53 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID2 GLOBAL Build/4.5.1_57_D2GA-59) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Love the cat tree! Nice and organized setup.
Old 09-21-2012, 6:33 PM
txzeke's Avatar
Default Antennas ??
What kind of antennas are those ? Are they actually Mobile Antennas with mag mounts ?
GRE PSR-500 / PSREdit500 / Pro96Com
Old 09-21-2012, 7:14 PM
bigmattyl's Avatar
Two Austin Spectras, a Laird 800Mhz and an Antennex from left to right. they are all mobile antennas that don't need a ground plane attached to magnetic mobile mounts stuck to the window sill
Old 09-21-2012, 7:42 PM
doctor795's Avatar
Looks great, do what you can in the restrictions and you have..GREAT
DOCTOR
Old 09-21-2012, 8:39 PM
slickchannels's Avatar
Top-floor apartments often have attic scuttle holes in the ceiling of a closet.
And if yours doesn't they aren't hard to create. Stud finder, keyhole saw, some baseboard molding, a square piece of plywood, paint that matches the ceiling and ... you're good to go.
PRO-197
Kenwood TS440SAT
And a buncha other crap
Old 09-22-2012, 7:34 AM
NYRHKY94's Avatar
Matt:
A real nice job with the set-up given the restrictions! Good maximizing of space and reception potential! Quick question for you. Mag mounts "typically" need some type of metal surface (acts likie a groundplane) to perform in an optimal fashion inside the shack. Some guys use a file cabinet, cookie sheet, AC unit etc. Looks like yours are on a non-metal window sill. Just wondering if you have tried a metal surface to see if your reception improves? I would think it should.
Thanks for posting the pics! P.S. Is that Pro-2066 on it's side (not a 2006)?
BCD536HP/BCD436HP/BCD996P2/BCD325P2/BCD996XT/BCT15X/PRO-197
Old 09-22-2012, 10:45 AM
Dann's Avatar
Looks Good.
Scanning South West Washington And The Portland Metro Area
Old 09-22-2012, 2:17 PM
Thumbs up
Nice station!
Oh, and the cat tree is great! They can sit there and smack your antennas when they get bored!
As others above has said, a metal surface under those antennas would help. Try a pizza pan or cookie sheet on top of a book case, or if you have a drop ceiling with the steel dividers, that's even better.
73,
n9zas
Old 09-22-2012, 11:31 PM
Rt169Radio's Avatar
Looks pretty nice, and like everyone else has said, the mag-mount antennas would do better if they were on something metal.
Old 09-23-2012, 1:47 AM
maalox's Avatar
very nice set up..
Old 09-26-2012, 1:32 PM
bigmattyl's Avatar
OK...
I'll give the cookie sheets a shot.. I didnt know if they needed them because the antennae didn't need a ground plane, but I'll admit my knowledge on antennas and optimization is shaky at best
Matt
Old 09-26-2012, 1:35 PM
bigmattyl's Avatar
Originally Posted by NYRHKY94 View Post
Matt:
Yup! I mistyped.. its a 2066... I leave on the main dispatch talkgroup for Orange County Fire Auth. so i dont miss a dispatch while messing around with other talkgroups!
I
"m gunna try and figure out a way to put some metal under there and see if that helps.. I'm shaky on ground planes and stuff and was try to avoid it by going with antennae that said they didnt need one.
Old 09-26-2012, 4:49 PM
bglatour001's Avatar
Try mounting your antennas to the top of the cat tree... assuming the cat doesn't mind... Lol
Every now and then, I catch my wife listening to my scanner.
VA3RIW
EchoLink Node 551400, Monitoring IRLP Node 2264 on VE3ONR
Old 09-26-2012, 10:25 PM
Nice set up bigmatty,
Do you like that condor antenna on the 245xlt ?
Also how does the 996 perform compared to the 796 units... I have a 15x. My next purchase will be the 996 or a new digital model. I have the austins ok my mobile....love that antenna.
Old 11-04-2012, 12:02 PM
KD2DLL's Avatar
Looks really good. Like the antennas
Alex KD2DLL
HTML code is On
