Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 10-25-2012, 9:15 AM
KaiserM715's Avatar
Default Kenwood install in '10 F150
After having my license since June and my radio since July, I finally had time to get it all installed.
I picked Kenwood based on several reviews discussing ease of use and programming. Not to mention, I have a local ham who uses them and has been helping me with programming. I know my antenna and mount selection may not be popular with some, but I needed something that won't get tangled up on tight trails and I didn't feel that mounting on the roof (the best option) would work out.
Here is what I installed:
Kenwood TM-V71A Dual Band w/ CAP mod (I bought it that way – allows TX up to 151.999Mhz))
Kenwood - TM-V71A
Kenwood DFK-3D panel kit (head unit separation kit)
Kenwood PG-5F extension cable
Comet CP-5N Lip mount
NCG Company::::::::::::::::::::::::::::::::::::::::::: :::::::::::::::::::::::::::::::::::
Comet SBB-5 antenna
Data cable off of eBay
Split loom
LOTS of zip ties
I soldered all connections and sealed them with adhesive heat shrink.
I decided to mount my antenna on the passenger’s side of the tailgate, the main radio unit behind the rear seat and the head unit on the center stack. Here is a good thread describing how to removed the upper portion of the backseat in a Super Cab:
How to remove 2009/2010 Supercab rear upper seat - F150online Forums
The best method I found was to stick my hand behind the seat and unclip the plastic mount with my finger, while pushing down a little on the top of the seat. I can probably get it out in under 30 seconds after having done it a couple of times.
I mounted my antenna mount on the tailgate, ran the cable along the edge and down under the bed. I also encased the cable with split loom for some additional protection.
In between the tailgate and the bed:
In between the bottom of the tailgate and top of the back bumper
The cable goes under the bed and into the frame rail, to keep it protected from gravel, etc.
I used a fish tape to route the cable though the frame rail. The cable exits at the forward most bed mount, and is routed through the cab vent behind the back seat.
Next, I worked on the power side of it. The extension kit I bought came with a long power cable. I soldered some ring terminals on the ends (also added heat shrink) so that they could be directly connected to the battery. Then, I inserted the wires inside of split loom and routed it along the existing wiring harness as well as the harness for my light bar (blue heat shrink).
Excuse the bad pics, I took them at night.
I used an existing grommet to get through the firewall.
Then I routed the wiring behind the passenger kick panel, under the sill plate and behind the trim panel behind the back seat. There is a pic of that later.
Now we will cover the wires for the head unit, mic and external speakers. After
With the main unit mounted behind the seat, the speaker would be pretty muffled. I bought a pair of relatively cheap external speakers (one for each channel). After some thinking over, I mounted them with zip ties to the front pedestals of the driver’s seat frame. I checked the path of the seat and it can move forward and back with plenty of clearance between it and the speakers. Here is a pic with the seat all of the way back:
Here are the wires for the head unit and mic. This is where the head unit wire enters the driver’s side of the console. The mic is plug into the extension connector, which is zip tied to the bottom of the seat track.
I removed the kick panels on each side of the center console. The head unit cable continues on inside of the console. The extension connector is attached to the heater duct with double sided tape (white connector behind the cable bundle). The remote head unit cable plug in here, with the excess bundled.
I routed the cable up through the console to the center speaker in the dashboard.
I ordered this mount from ProClip:
Ford F-150 - 2009-2013 - ProClip Center Mount*-*ProClip Car Mounts for Mobile Phones, Tablet, and Handheld Devices
It is a pretty good solution, but for the price point, I was a little disappointed in the fit and finish.
I drilled a hole pattern to match the head unit mount and screwed it all together with the screws from the radio. Then, I drilled a 1/2" hole in the center speaker plate to run the cable through and routed the cable up through the dash using a fish tape.
Here is the hole (the rubber cover conceals it very well and lays pretty flat in that corner):
Here is the head unit mounted:
I bundled the head unit, mic and speaker connectors together, inserted them into split loom and routed them along the bottom of the driver’s seat track (in between the seat track and the console) across the back floor board and under the back seat.
Now with the floor mat on top
I picked this location as it worked well with all of my other plans for cable routing, is in a low foot traffic location and with the mat installed is fairly protected.
Now for the main unit. I installed this after the antenna, but I wanted to discuss all of the cable routing, too, so I will cover it all here. I picked behind the seat for a couple of reasons. I park outside, so this is completely hidden. Also, I don’t have to worry about it being kicked or stepped on. After removing the back seat, I looked at several locations for mounting. I picked this location based on room for the unit for cooling. I marked the location and removed the rear sound insulation (it attaches with 5 christmas trees). I trimmed the insulation with shears to allow for plenty of room around the main unit. Then, I marked and drilled the rear cab wall for the mount. I used stainless bolts, washers and lock nuts. I also applied silicone under the head of the nut and on both sides of the washer, for exterior sealing. I had a buddy come help me install this part. Afterwards the insulation was reinstalled. Then, I hooked up the cables, coiled the excess and zip tied everything together.
Here it is, all installed:
The wires on the left: power, antenna and programming. The wires on the right are head unit, mic and aux speakers. The bulge just up and to the right of the main unit is the power sliding window motor. I plan on shortening the antenna cable when I get a soldering iron with more power.
One word of caution. Quite a bit of the mounts, etc back here are SHARP. They were stamped out without dressing the edges. I sliced up my fingers a couple of times without noticing it until I saw all of the blood.
Referring to the pic above, the programming cable enters some split loom and goes off to the left. I routed it around and zip tied to the rear seat mount for access with the rear seat in. As I usually have a kiddy seat in the back, this will make programming much easier.
It will stick out far enough for me to hook my usb cable up and then tuck back behind the seat belt when not in use.
This was a pretty time intensive install for me. I worked on it for most of one weekend (all day Sat and all of Sun afternoon) and an additional Sunday afternoon. I spent quite a bit of time thinking about where to route things, etc. Your mileage may vary...
Old 10-25-2012, 6:25 PM
Does this install clear the passenger air bag?
Old 10-25-2012, 8:21 PM
KaiserM715's Avatar
Yep. The passenger airbag is on the front of the passenger side dash and the head unit is slightly on the driver's side of the top, center portion of the dash. Well clear of any airbags.
'10 Ford Raptor
Old 10-25-2012, 11:23 PM
FD5722's Avatar
I'm a fan of people that take time on their installs and I give you two thumbs up my friend !!
Daniel
Old 10-26-2012, 8:09 AM
Rt169Radio's Avatar
Looks like it was done nicely.
Old 10-26-2012, 11:06 AM
W9BU's Avatar
Lead Wiki Manager
I see you've been out playing in the mud with your Raptor.
I have a 2011 F-150 XLT SCrew 4WD with the 5.0 V-8. Love the truck. I ordered mine with the bucket seats and center console because I knew the console would be easy to remove. The stock console came out and a Jotto Desk Lazy-L console went in. Most of my radios are mounted in the console, but there are other radios I want to add and the back wall of the cab is in my crosshairs.
So, you mounted the radio's RF deck bracket directly to the back wall of the cab? I've looked at high-end stereo installs on the various F-150 forums and it seems that most of those mount a piece of plywood or particle board to the back wall and the attach their gear to the board. I'm worried about the additional space the board would take up, so I haven't pursued that option. Are you still able to fold the rear seats up flat against the back wall?
I also used the ProClip mount for the control head of my Kenwood TM-D710. I think this is the single best thing I've done as it's great to have the head up where you can see it. I loomed the control head cables together and ran them down along the silver trim piece and in through the steering wheel opening. It's not the best and I may have to look at your solution.
Did you consider fishing the cables under the carpet between the front and rear seats?
How are the speakers working out for you? Seems like facing them towards the back side of your thighs would muffle the sound.
Good work on your install!
Lead Wiki Administrator
Moderator for the Radio Reference Amateur Radio Forums.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- Joe Walsh WB6ACU
Old 10-26-2012, 11:35 AM
Jay911's Avatar
Send a message via Skype™ to Jay911
That's definitely an interesting place to mount the antenna. Two questions - one, how's your reception, and two, can you adjust the whip to go vertical in the event you need to have your tailgate down for something?
Old 12-04-2012, 8:02 AM
KaiserM715's Avatar
Thanks for the compliments.
I bought it to enjoy it off-road!!
I mounted directly to the back wall to give as much clearance as I could for cooling. In the Super Cabs, like mine, the back of the rear seat is fixed, only the bottoms fold up and down. It took some trial mock-ups before I was sure it would work.
It did not occur to me to run the cables under the carpet and definitely would not have had time when I did the install. I might look into that for the future.
The location of the speakers has worked out fine. The only time I have any issues hearing things clearly is cruising down the hwy at 60+ with all of the windows down.
I got the idea from a fellow off-roader. My reception has been great so far. I have not had any issues receiving on of the repeaters in my area from over 50 miles out or transmitting to at over 20 miles out on medium power (10W).
I could readjust the mount, but would need to take wrenches with me to loosen and retighten everything. The only time I haul with the tailgate down is to Lowes and back, and then I usually just unscrew the antenna.
'10 Ford Raptor
Old 12-04-2012, 10:44 AM
W9BU's Avatar
Lead Wiki Manager
The rear seat back on the SCrews appears to be fixed, but it's not. As you fold the seat bottom, the seat back actually moves a bit. Turns out there are pins which fit into brackets to hold the seat back to the back wall of the truck.
It's a pain, but you can reach down between the seat back and the wall (near the head rests) so you can slide that pin a bit which releases the seat back so it can fold down. This gains you access to the entire back wall of the truck. I don't know if SCabs have the same seat attachment method, but they might.
Old 12-04-2012, 10:50 AM
russellmaher's Avatar
Send a message via Yahoo to russellmaher Send a message via Skype™ to russellmaher
Very nicely done! It must have been pretty intense, but a labor of love, and thanks for the details. It's like a tutorial for F150 owners.
Russell
SEMPER PARATUS
BCD396T BCT-7 BCD350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050
Old 12-04-2012, 1:59 PM
KaiserM715's Avatar
I had heard that the seat-backs tilt on the SCrews. It sounds like seat-back removal is different between the two cab styles. For the SCab, I had to squeeze my hand behind the seat and release a plastic tang on each side. After that, the seat back is lifted out so that the clips on the back of the seat clear the slots on the cab wall.
Sure thing. Glad you found it useful.
'10 Ford Raptor
Old 12-04-2012, 2:31 PM
Like the color of your truck,Kenwood makes a great radio!
Old 12-13-2012, 7:07 PM
GrumpyGuard's Avatar
Good clean install. Everything is done neatly and most importantly it works for you.
Tags
f-150, f150, install, kenwood, tm-v71a
HTML code is On
