| Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. |
11-06-2012, 8:09 AM
New Shack Still under construction
Here are two pictures of my Shack. Custom built desk. Radios and equipment are in place to check positioning but not hooked up yet. Still have to do some trim work on the desk itself. There is a partition under the desk that has removable panels which sits 6" away from the wall to hide wiring. It has cable management brackets throughout. More photos to come as I progress. I took the photos using a fisheye lens so it appears as if everything is rounded but it's not. All straight edges. Please let me know what you think. I need some more ideas.
11-06-2012, 8:40 AM
That looks quite nice, the walls need stuff (pictures, posters, etc.) on it though.
11-06-2012, 8:41 AM
Very nice keep up the good work.
11-06-2012, 9:49 AM
Keep taking the pictures before it's in use, because it'll never be that clean of a desk again
If you're building the desk yourself, then perhaps consider making a wooden section to sit atop the desk loosely, and rack mount the radios with hangars for the mics on the side, and leave it loose atop the desk so it can be turned to add/change/modify/repair/replace. It would also free up a little bit of real estate on the desk surface. I've also seen many on here with walls that big to fill add a flat screen TV or two, one to monitor radio stuff (such as ADSB, APRS, ATCS or weather radar) and another to monitor local news or watch the game while at the radio. One of the DX and maiden head maps and a local map if you're doing any public safety scanning or section chart for air scanning may also be helpful decorations.
Amateur Extra, GMRS (licensed)
Icom 92AD Yaesu FT-7800, FT-2900, FT-270
Icom F21GM, Motorola T7400, T6320
Kinetic SBS-1eR Uniden996T, RS Pro106, Pro-164, Pro-95
11-06-2012, 3:39 PM
i always like the stacking radios instead of speading them apart. thats cool that you got all that room!
11-06-2012, 4:06 PM
Very, very nice! Looks like this will be a place to spend many, many hours. Good job!
Russell
SEMPER PARATUS
BCD396T BCT-7 BCD350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050
11-06-2012, 4:32 PM
Don't forget the radio model names and etc.
Callsign: N4CYA
MotoTRBO: Motorola XPR 5550
Scanner: Uniden BCD996XT
11-06-2012, 5:04 PM
Lead Wiki Manager
Looks like you are making good use of limited space. I'm guessing that room is about 10x10 or maybe 10x12. I have the same limitation, so I'm interested to see how your room turns out.
Lead Wiki Administrator
Moderator for the Radio Reference Amateur Radio Forums.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- Joe Walsh WB6ACU
11-14-2012, 1:04 PM
Great setup! Looking forward to seeing the updates!
 Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
11-14-2012, 1:10 PM
I like it. Very clean and spacious looking, however...
bears repeating. The walls are too plain.
^--^ PRO-106...just 1 for now until I can find a good deal on another scanner^--^
11-22-2012, 8:06 AM
Looking good nice custom ham shack.
11-22-2012, 3:35 PM
Hit up monoprice and get some wall or desk mount arms for the monitors -- nice to reclaim the space underneath them and let you move them around in 3 dimensions (with the right mounts of course).
You can never have enough power outlets within easy reach either.
And, that one empty wall there is screaming for a ~42" screen that you can use as a monitor or TV...
Travis D.
KB3WUQ
11-22-2012, 4:54 PM
Good point, travisd....one can never have enough outlets.
Russell
SEMPER PARATUS
11-26-2012, 7:25 PM
Very nice!
Icom V80 & R20, Uniden BC346XT
11-27-2012, 2:03 PM
thats very nice, almost looking like a bunker
73's Doug
Kenwood R-5000 / Elad FDM-S1 SDR / Wellbrook ALA-1530 / various software decoders
Brisbane, Australia, UTC+10
11-27-2012, 10:44 PM
Awesome............
11-28-2012, 12:11 AM
Updated Photo
It's a bit messy due to the installation but here is an udated photo. I liked the idea of a large monitor so I went with a 50" monitor. It is switchable between computers. Put up some pictures and stuff too. Need to save some wall space for a World Map for my HF contacts.
Radios: (not all installed yet).
Motorola CDM1250 VHF
Motorola CDF1250 UHF
Motorola Spectra 900MHz
Motorola MTS2000 800MHz
Kenwood TK-5210K3
Kenwood TK-380
Bendix King DPH-CMD
Kenwood TM-451A 1200MHz
Kenwood TM-V71A 2M/440 X 2
Kenwood TM-V7 2M/440
Icom IC-2100 2M
Yaesu FT-757GX HF
Palstar AT1500CV Tuner
Alinco DX-70 HF/6M
Uniden BCT-15 (i'm not a scanner guy).
Also have a very sensative security system that detects motion inside and out and a Ubiquiti Airvision IP Camera system running airvision which is viewable from my blackberry or CF-29 in the truck.
11-28-2012, 12:22 AM
I spotted that Palstar tuner the first glace I took of you gear. Doesnt help out for the scanners, but as far as HF goes, you cannot find a better tuner.....I could even tune up a bowl of wet spagetti!
Also, you have to love that little switch inside the 757....
Best of luck with it all.....a shack you can be proud of for sure.
73 de KI4VBR ... -.-
Vince
KI4VBR
Listening to: Icom 756Pro3, 706mk2G,730, Icom 2200H, RX7 Govt/Export, FunCube SDR, Yaseu 857D, Flex3000 SDR, 811h, FT-60 dual band, 396XT, 895XLT, HP1, Pro-95, Pro-97, Stridsberg Active Multi-Coupler
11-28-2012, 12:24 AM
Man Cave
Its starting to look really good
11-28-2012, 3:16 AM
Looks great. The only thing that is missing is the cot. That way you only have to leave for food and ...
HTML code is On
