Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 12-14-2012, 4:06 PM
Default Ford Escape 2012
Here are some photos of my newly completed install of my mobile shack.
1. Havis Vehicle specific console
2. CDM 1250 x 2 ( vhf 136-174, uhf 450-520)
3. Gre Psr 600 ( Digital )
4. Gre Psr 410 ( Analog )
5. 3 NMO Antennas
1. low profile Motorola 700-800 mhz antenna
2. low profile Antennx uhf ( 450-470 mhz)
3. Motorola vhf antenna
The power source I established is surely overkill for my needs because I am not transmitting. I used 8 gauge wire with a 40 amp reset-able circuit breaker. I used a solenoid to allow protection on draw from my battery, I also used 2 terminal posts to distribute the power. My entire system is wired off my ignition circuit.
Old 12-14-2012, 4:15 PM
KC0CSE's Avatar
Question
5. 3 NMO Antennas
which one is the 800mhz antenna ?......
Old 12-14-2012, 4:18 PM
The most forward low profile antenna. It a motorola XTL 5000 mobile antenna.
Old 12-14-2012, 4:26 PM
KC0CSE's Avatar
ok the one that is the tallest that looks like a cell antenna..wanted to make sure...thanks
Old 12-14-2012, 8:41 PM
Sorry I was not clearer. The fowardmost small black low profile antenna is my 800 mhz antenna. The silver longer antenna I am using as my all band antenna. Surprisingly that antenna which is only 10 inches receives low band very well.
Old 12-15-2012, 6:38 AM
gr8rcall's Avatar
Very nice,
Pictures are great quality!
What kind of camera did you use?
~Gr8rcall
Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
Old 12-15-2012, 9:29 AM
Rt169Radio's Avatar
Good setup, the low profile antennas are a nice touch.
Old 12-15-2012, 2:35 PM
Originally Posted by gr8rcall View Post
Very nice,
~Gr8rcall
I actually took the pictures with an Iphone 4
Old 12-15-2012, 4:05 PM
fasteddy64's Avatar
Send a message via Yahoo to fasteddy64
Most impressive!
Old 12-15-2012, 5:07 PM
Good Looking Detup
Scanning South West Washington And The Portland Metro Area
Old 12-15-2012, 11:33 PM
Send a message via AIM to Rob_K
Great install. Just a question/comment...
Along with your main circuit breaker, do you have fuses on the power leads for each radio or scanner? Correct me if I'm wrong but I believe a breaker can be too slow to "react" to protect electronics. The fuses on the power cords would offer the protection you need.
Old 12-16-2012, 6:53 PM
What do you think of the 2013 Escape redesign?
73,
N9TCP
Old 12-16-2012, 8:30 PM
Yes I used all of the power cables included with the install kits. Those cables have in line fuses.
Old 12-16-2012, 8:31 PM
I personally dislike the 2013 ford escape. I like the box style over the new European style.
HTML code is On
