Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 01-12-2013, 2:16 PM
Default 2009 Hyundai Tucson BC355N Install
My humble mobile scanner setup. Just got done. I wanted to mount the antenna toward the rear and bring it in the bottom of the hatch, but the cable was not long enough. So, I had to make do with bringing it in the passenger door. Luckily, the construction of the B pillar allowed me to run it that way.
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT, RadioShack PRO-2014, Bearcat 210XL
Old 01-12-2013, 2:17 PM
Never even know it was in there.
Dave
Dave
Old 01-12-2013, 2:27 PM
bobmich52's Avatar
I Had My 996 Set Up The Same Way You Have DMG Until I Got The HP 1
Using The Bracket That Came With It
Had Glass Mount Antennas X 2 4 Mounted In The Rear L/R Windows And I Tucked The Excess Line Behind The Rear Seats
Antenna I Have Now, A Larsen Nmo 150/450/800 Run Through The Firewall Of My Tucson Works Great, Even In The Low Bands
Old 01-12-2013, 4:21 PM
zl2taw's Avatar
nice & simple
Did you try running the antenna cable under the door trim ?
73's Doug
Kenwood R-5000 / Elad FDM-S1 SDR / Wellbrook ALA-1530 / various software decoders
Brisbane, Australia, UTC+10
Old 01-12-2013, 4:37 PM
Rt169Radio's Avatar
Looks pretty nice.
Old 01-13-2013, 6:17 AM
bobmich, I considered the Larsen, but opted for the SpectrumForce since most of what I listen to is VHF low. So far, I am not impressed. Going to post about it in the antennas area. Already considering changing to the old radio shack two coil that they still sell. I was always impressed with its performance. It's what I used to use when I had a mobie in my vehicle.
zl2taw, I did run the antenna cable under the trim once I got it in the passenger door. Then under the 2 mats and up to the scanner. It's amazing how short 12 feet of cable can be....
Thanks, Rt169Radio.
Dave
Dave
Old 01-13-2013, 6:48 AM
SouthSideScannerGuy's Avatar
Looks good. I like how the wiring "disappears" once the doors are closed. The clips are a good idea too.
HOME PATROL-1 / BCT15X / BC346XT / BC125AT / BC355C /
PSR 800 / PSR 310 /
PRO 163 / PRO 164 / PRO 107 /
FT2800M / KG-UVD1P / UV-5R / UV-3R (x2)
Old 01-13-2013, 7:16 AM
Thanks, SouthSide. That location for the antenna was a "fall back and regroup" effort, but I'm satisfied with how I was able to run it. There was JUST enough room there for the tie wrap mounts to clear when the doors closed.
Dave
Dave
Old 01-13-2013, 8:01 AM
Rt169Radio's Avatar
Where did you get those clips? Can they get any bigger?
Old 01-13-2013, 8:11 AM
Rt, I got them at Radio Shack. My brother called them tie wrap mounts. I'm sure you can get them larger.
Dave
Dave
Old 01-13-2013, 10:54 AM
Looks Good.
Scanning South West Washington And The Portland Metro Area
HTML code is On
