Go Back   The RadioReference.com Forums > Topic Specific Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups.
Old 01-14-2013, 8:55 PM
SouthSideScannerGuy's Avatar
Default BC125AT mobile
Was going to install my PRO-163 in my car, but decided to go a different direction with it, so I wanted to find a way to use one of my portables in my car (2005 Neon). Was at a local flea market this past weekend and came across a booth selling cell phone accessories (one out of about two dozen or so LOL). Stopped to look at the cell phone holders and found one that clipped onto the heater / ac vents. The price was right so I bought it. It's a simple set-up, but it looks like it will work out pretty well, although I don't think it's study / heavy enough to hold my PSR-310, so I'll be using the 125AT in it. Just need to get a right angle connector for the antenna wire and I should be all set.
HOME PATROL-1 / BCT15X / BC346XT / BC125AT / BC355C /
PSR 800 / PSR 310 /
PRO 163 / PRO 164 / PRO 107 /
FT2800M / KG-UVD1P / UV-5R / UV-3R (x2)
Old 01-14-2013, 9:10 PM
doctordialtone's Avatar
Nice!
Actually I had the same device. It worked great for just holding the scanner, was a little flimsy for pushing any buttons.
A word of caution. In my case, those plastic fingers you push into the vent messed up the plastic pieces connecting the vertical louvers, so they don't move in unison anymore. I'll survive.
I'm using a smart phone dashboard mount with a little help from the folks at VELCRO ® these days, which isn't very industrial either.
Good luck!
~Doctor Dialtone
BCD996XT, BCD396XT, PRO 2004 Modified, BC2500XLT Modified, Minitor V
This post is worth another 4 RR points towards free trips and other valuable discounts!
Old 01-14-2013, 9:32 PM
xxdanielt3's Avatar
I thought about purchasing one of those mounts as well, steered away cause I didn't want the heat blowing right on my scanner, dumb I know.
I opted to go with a cupholder mount with a neck and I too drive a Dodge Neon.
I'll shoot you a PM seeing I have some antenna questions.
RadioShack Pro-164 - Uniden BC95XLT - Motorola Minitor III - Kenwood TK-3302U - Baofeng UV5R - Minitor II - (2) Minitor V
Old 01-15-2013, 8:28 AM
Rt169Radio's Avatar
Nice and cool.
Old 01-22-2013, 2:06 PM
SouthSide...I just purchased the BC125AT today to use in my vehicle. Do you power it with the DC adapter or just use the batteries? I see the external antenna wire going behind and coming out near the bottom, but no power cord. How is the battery life? Can you turn the backlight off during the day or is it on all the time? What type of antenna are you running? My requirements are probably a little different than yours, but I was curious. I just bought a Radio Shack 25-1300 MHz magnetic mount for the BC355N I originally bought to use in my vehicle. I couldn't get rid of some interference on VHF low, so I am using that as my new base. I will just use the RS antenna for the portable.
Dave
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT, RadioShack PRO-2014, Bearcat 210XL
Old 02-04-2013, 11:46 PM
Well, I guess it's back to the drawing as far as mounting my 125AT in my car. That holder I bought is okay for cell phones, but not too good for scanners. On quite a few occasions when my car has hit a pothole, it has caused the scanner and holder to get jostled and has pulled the vent off of its hinges, so to speak.
I have a cup holder mount, but it's pretty much a piece of junk, so I won't be using that. I'll have to do some looking around and see what I can come up with.
PSR 800 / PSR 310 /
Old 02-05-2013, 8:35 AM
Try this one from The Mount Guys. Car Cup Holder Mount for Uniden GE Radio Shack Cobra Bearcat Wouxun & Other Handheld Scanners Radios & Walkie-Talkies
I have been using it since I got my 125AT and I have not one issue. It holds it secure as can be. See my thread for photos of it in my Tucson.
Dave
Dave
Old 02-05-2013, 10:44 AM
Dave
That's the same cup holder mount I have now that doesn't work very well. I can never get it to securely stay in the cup holder, let alone have it in there straight, no matter how much adjusting I do to the thing.
Wish it worked as well in my car as it looks like it does in yours.
PSR 800 / PSR 310 /
Old 02-05-2013, 11:47 AM
That's too bad because I am very happy with it. Each car is different though. Are your cup holders tapered at all? I looked at some images online and couldn't really tell. I just put mine in and really cranked on the dial to tighten it against the sides. Then I adjusted the angle and the ball fitting to rotate it right where I wanted.
Dave
Dave
Old 02-05-2013, 7:33 PM
dispatcher812's Avatar
How well does it work in that setup? Looking to go that route myself.
Kevin Fitzsimmons
Uniden BC355 in the truck, a BC350A hosting a feed and a BC125AT playing several rolls.
Old 02-06-2013, 6:22 AM
Are you talking to the OP or me? If you are talking about the OP's vent setup, he is not happy with it. If referring to my cup holder mount, I am happy with it in my vehicle.
Dave
Dave
Old 02-06-2013, 7:10 AM
Dave
Sorry, I should have been more specific, I meant how does the BC125AT perform as a mobile?
Kevin Fitzsimmons
HTML code is On
