Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 02-09-2014, 5:19 PM
Database Administrator
Default 2009 Jetta and BCD436HP
Photos of my 2009 Volkswagen Jetta TDI with BCD436HP installation. Also have a Garmin GPS attached and 1/4 wave VHF glass mount antenna on the windshield. Both the GPS and scanner are wired hot and I installed a kill switch below the dash.
Tim
BCD536HP (House) / BCD436HP (Car)
Live Feed - http://www.broadcastify.com/listen/feed/19486
Old 02-09-2014, 5:28 PM
russellmaher's Avatar
That looks good Tim.
How did you secure the scanner bracket where it enters the seam next to the radio?
Or is it just a press fit into the seam?
Anyway, how do you like the performance, and is it what you expected or more?
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
Old 02-09-2014, 5:29 PM
The bracket is a panavise bracket. It is a specific fit for the car. It shares screwed under the trim with the radio and the climate control.
Tim
Old 02-09-2014, 5:37 PM
More photos
Tim
Old 02-09-2014, 5:44 PM
And as far as the performance. I started with a BCD396XT when I got the car and then switched to a HomePatrol and just switched out to the BCD436HP. This is by far the best scanner I have had in the car so far. Simulcast decode is awesome compared to the other two and now I can pick up the Phase 2 system in my work area. GPS is awesome for the amount of driving that I do.
Tim
Old 02-09-2014, 5:45 PM
i like that setup man my corolla has a similar dash setup
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
Old 02-09-2014, 8:32 PM
NWI_Scanner_Guy's Avatar
A very nice and clean install. How's the performance of the glass mount antenna?
PRO-2051 / BC-355C
BCD436HP / BC-246T / BC-125AT / PRO-137
Alinco DR-605 / UV-82X / UV-82HP / UV-3R+ / JT-UV71
Old 02-09-2014, 8:39 PM
Thank you. It has done very well and surprisingly it is doing well for reception for all bands. I mostly monitor low band, UHF and 800.
Tim
Old 02-09-2014, 8:44 PM
I love how you have the antenna mounted & your clean wiring. Very nice!
~Scannaman9
Old 02-10-2014, 7:06 AM
got a link for that mount and do they have any for a corolla and a pro-106?
Old 02-10-2014, 7:14 AM
dmg1969's Avatar
Nice install tknepp! Neat and tidy.
recon, go here. Toward the top, you will see any area to put in the make. It will then have several for Corolla based on the year. I looked at one for my HP-1 in my Tucson, but opted for a dash mounted RAM mount. PanaVise Products, Inc.
Dave
My Scanners: HP-1, BC125AT, BC355N and Baofeng UV-5R2
Founder Perry County Pennsylvania Scanner Enthusiasts Group on Facebook
https://www.facebook.com/groups/407409399385884/
Old 02-10-2014, 12:45 PM
Dann's Avatar
Looks great.
Scanning South West Washington And The Portland Metro Area
Old 02-10-2014, 7:48 PM
Also you can try Pro.Fit International - Producing Cell Phone Holders and Car Mounts with a professional fit
Tim
HTML code is On
