Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 04-27-2014, 11:42 PM
LouisvilleScanMan's Avatar
Default 2003 Chevy Suburban CB Install
I helped a buddy install a CB in his Suburban. Here's a link to the pics.
https://www.facebook.com/media/set/?...8652780&type=3
Bluegrass/KI4RDG
A.R.T.S. REACT ARES RACES SKYWARN
LouisvilleScanMan.com
JeffersonCountyARES.org
Old 04-28-2014, 3:12 AM
brutalpilot514's Avatar
Nice install. My next truck will be that same body style and it's nice to see examples of radio install.
Pro-94->PSR-500 (FINALLY!!!!)
Old 04-28-2014, 4:36 AM
pinballwiz86's Avatar
Nice install! Lot of work went into that.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 04-28-2014, 4:38 AM
You have no freaking idea. we started working at 3PM and finished at 4AM! And unfortunately the radio is getting a TON of ignition noise. Not sure how to fix that.
Bluegrass/KI4RDG
Old 04-28-2014, 9:24 AM
n4yek's Avatar
Nice and tidy and drillin' holes... oh yea...
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 04-28-2014, 6:46 PM
I have a Magnum 257, seems to work but I haven't made contact yet, I can hear myself loud and clear on AM but no one can hear me . I do hear a lot of people from around the world, Puerto Rico ch9 and Venezuela, Mexico in other channels.
GMRS user
Old 04-28-2014, 7:18 PM
jhooten's Avatar
Where did you pick up the power and ground?
Take the power to the the stud in the red box near the Alternator and the ground to an alternator bracket bolt.
Next time take down one of the dome lights and drill above it then fish the cable across to save the time of removing the headliner.
Jerry
I read it on the internet, so it must be true.
Old 04-28-2014, 9:48 PM
WD4JKH's Avatar
27.145 FM? Seriously?
Old 04-29-2014, 5:12 PM
One of us bumped the mode button and didn't notice until later.
Bluegrass/KI4RDG
Old 04-29-2014, 5:15 PM
The power and ground go straight to the battery.
He wanted the antenna in one particular spot...he's weird like that.
Bluegrass/KI4RDG
Old 04-29-2014, 10:58 PM
62Truck's Avatar
Nice install, Nice to see it wasn't just thrown in. With the ignition noise its a pain on HF. I know when my step father was installing his FT100D he ended up doing a lot of grounding. Now do you get the ignition noise on RX or when TX or both?
When I used to work for a radio shop we had issues with M1225's in school busses, we would install a kenwood KLF-2 filter.
Lions, Tigers, Bears....
Old 04-30-2014, 12:54 AM
We found that the noise isn't the ignition, it's being caused by the alternator and it's only on RX.
Bluegrass/KI4RDG
Old 04-30-2014, 8:25 AM
parkerbs's Avatar
Ground the radio closest to the radio it`s self not to the battery that will take care of the alternator whine.
Sent from my LGL86C using Tapatalk
Old 05-01-2014, 9:45 AM
I got little less noise in my radio, in my previous vehicle, when I ran every thing to the battery. I replaced the battery, in that vehicle, with one that had top and side mounted posts. I tried connecting all my radio stuff to the side posts and the vehicles connections on the top posts and got a LOT less noise in the radio even with the squelch all the way down. Still had a little but it was barely noticeable.
Couldn't find anything on the net advising against it. I have found TSBs and other sources advising not to connect ground wire, to two way radio(s), to the chassis but to go directly to the battery and fuse both leads.
FWIW.
Old 05-01-2014, 9:58 AM
parkerbs's Avatar
The chassis of your vehicle is connected to the battery. If you know the answer why ask the question. I have had countless radio setups and having the shortest ground is always advised on anything you install in a vehicle.
Old 05-01-2014, 9:19 PM
parkerbs's Avatar
I just want to clarify. When i say ground closest to the radio i mean to the chassis of the vehicle not the radio itself. Running to the battery woth your ground can and most likely will result in alternator whine. Sorry if i was unclear.
Tags
2003, cb radio, chevy, suburban
HTML code is On
