Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 07-14-2014, 5:27 AM
Default 2012 GMC Sierra Instal
We ran power through the factory gromet and through factory wire loom to the battery.[ATTACH]46619 [/ATTACHName:  uploadfromtaptalk1405329958131.jpg
Size:  77.1 KB The Coax was ran under the headliner from directly under the dome light. We used a stinger to pull the coax through. This helps especially because you do not have to drop the head liner. The coax was then routed through the weather stripping on the driver side door and routed behind the fuse box and ran under the carpet with the power and into a small 3/4 in. hole that was drilled in the locking center console under the center seat.Name:  uploadfromtaptalk1405329967545.jpg
Size:  60.6 KBThe Radio and Wouxun KGUV920P-A was installed in the hidden compartment that locks which is a nice feature and is well hidden!Name:  uploadfromtaptalk1405330014499.jpg
Size:  28.5 KB The PCTEL Dual Band AntennaName:  uploadfromtaptalk1405330023167.jpg
Big thanks to John N0XG for helping greatly with the install. Couldn't have drilled a hole in my shiny new truck by myself!
Old 07-14-2014, 10:12 AM
profiledescent's Avatar
I'd cut out the unused bundled coax.
Old 07-14-2014, 5:15 PM
Really nice to see an install on a newer Sierra, I can't find to many threads on them. Looks good!
73's.
-KG5CAY
Old 07-15-2014, 12:27 AM
eaf1956's Avatar
That interior looks just like my 2013 Silverado, except the center rest which is different.
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600, CS 800D, and a YAESU FTM400DR
Old 07-15-2014, 2:29 AM
b7spectra's Avatar
EMS Dispatcher
How well does the Wouxon work? I've been looking at them but haven't pulled the trigger yet. Will it also do Alpha-Numeric?
\/\|k.e
EMS Dispatcher/Advanced EMD Certified
EMT/Paramedic, retired
Old 07-15-2014, 5:12 AM
Rather have extra just in case I ever need it!
Old 07-15-2014, 5:13 AM
73's.
-KG5CAY
Thank you! I couldn't find many either I hope this is inspiration to others who have similar trucks!
Old 07-15-2014, 5:14 AM
The Wouxun works great! I would get it from universal-radio. It's about 100 bucks cheaper on there and yes it will do Alpha-Numeric Display!
Old 07-15-2014, 3:19 PM
If I may ask, where did you run the wires through? Yes you say factory gromet but honestly where was it located? I have a 2011 Sierra and the only gromet I was able to find in the dash was under the steering wheel right behind my fuse box, which would require me to disassemble my fuse box to use that gromet. What I did was run my wires under the cab through an existing hole capped off (for a future gromet use).
-KG5CAY
Old 07-15-2014, 11:25 PM
b7spectra's Avatar
EMS Dispatcher
Did they fix the issue with the aircraft band and it's now AM instead of FM? Thanks for the info!
\/\|k.e
Old 07-16-2014, 3:46 AM
-KG5CAY
The Gromet that was used was just behind and above a black box just to the right of the fuse box. A few small cuts with a pocket knife made just enough room to get power through.
Old 07-16-2014, 3:47 AM
I have no idea I don't really listen to Air Band so I wouldn't know.
Old 07-17-2014, 10:09 AM
Seriously? That's a pretty fundamental mistake.
Old 07-19-2014, 11:45 PM
b7spectra's Avatar
EMS Dispatcher
It is Chinese you know!
\/\|k.e
HTML code is On
