Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 08-11-2014, 7:49 PM
firemedic2150's Avatar
Senior Member
Default Updated my home desk scanners and radios
Did a little updating to my desk at the house after seeing Rich W9JIG do his racks, I could not afford to do what he did but I did get a second 3 scanner rack for my radios and new BCD996XT.
The desk is a Hon desk I bought at a scratch and dent sale 10-12 years ago, The computer is a Dell tower I have had for long time running dual 21" Dell widescreen monitors.
The left rack has my VHF and UHF CDM1250 radios and in the top is a BCD996XT I picked up a few weeks ago at the local Radio Shack for $99.00! that I am using as my general scanner right now for what ever strikes my mood. The right rack has another older BCD996XT that scans the TVRCS Chattanooga P25 simulcast. The top BCT15X right below it scans the older Chattanooga/Hamilton County system. Things are locked out in each so they do not duplicate things that are on both systems. The bottom BCT15X is mainly for area conventional scanning. On top of the right rack is a Icom ID880H Dstar radio which is on the W4PL system in Chattanooga most of the time, The Kenwood TMV71A under it is my general use radio. I am having a hard time managing the two microphone cords for the amateur radios.
The BCD996XT on the left and the two BCt15X scanners are connected to a older ST2 antenna in the attic using a Stridesberg 4 port multicoupler. The other BCD996XT has a tuned 800 Mhz rubber duck portable on a right angle BNC to avoid P25 simulcast issues. the Kenwood TMV71A is connected to a Comet GP-3 in the attic. The Icom ID880H is connected to a comet B-10 mounted to a NMO drilled in a 16 inch pizza pan in the garage. And the UHF CDM1250 is connected to a Sinclair UHF antenna in the attic. The VHF CDM1250 to a homemade J pole in the attic.
Rule #1 "Common sense and logic will not be tolerated"
Old 08-11-2014, 8:47 PM
03msc's Avatar
NICE setup and you got a deal on that 996xt! Thanks for sharing your station with us. Inspiring!
EDIT: Since you have dual displays, check into DisplayFusion for spanning wallpaper across both screens or using a different wallpaper on each - they have a free version or a paid version. Just a suggestion if you're interested!
Mark Arkansas K D 5 B V X
Uniden and Whistler Scanners Kenwood and Yaesu Radios
Old 08-11-2014, 8:52 PM
Jimru's Avatar
Very spiffy, indeed!
Addicted to all things radio for nearly 50 years, and proud of it!
Old 08-11-2014, 9:17 PM
NWI_Scanner_Guy's Avatar
Very nice set-up and a nice selection of equipment.
PRO-2051 / BC-355C
BCD436HP / BC-246T / BC-125AT / PRO-137
Alinco DR-605 / UV-82X / UV-82HP / UV-3R+ / JT-UV71
Old 08-11-2014, 10:11 PM
flythunderbird's Avatar
Well done! Looks great!
Glenn
"I got some radios ... I listen to some stuff ..."
Old 08-15-2014, 12:09 AM
WatnNY's Avatar
Well that answers my question if the CDM's will fit in those scanner desk top mounts! Looks like I may have to order another one to put my CDM's in!
Scanners: BC250D, BCD536HPx2, 996XTx2, 996P2, PRO-92
Ham: Icom 208H, Kenwood TM-V71
Pro: Icom F3061 & F5061, Kenwood 7081 & 8081, Motorola CDM1250, XPR4550x2, XPR6550, XTL2500, XTS5000
Old 08-15-2014, 5:06 PM
Senior Member
WatnNY,
You will need about a 1/2 spacer for each side they are just over and inch narrower than the scanner stand. I went to Lowes and got some 1/2 inch thick poly washers and some longer metric screws to mount them, and it still pulls the sides in just a bit, I could add just a regular washer and probably make it fit better but its not bad.
Old 08-15-2014, 6:16 PM
pinballwiz86's Avatar
Looks great! What kind of hook-up do you have for the Unidens? Coax?
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 08-16-2014, 12:26 PM
slapshot0017's Avatar
How did you find the scanner for so cheap??? I will go pick one up for myself if this is the case in most places! Sweet setup too!
Old 08-17-2014, 2:51 PM
BoxAlarm187's Avatar
Looks great, very nice job!
When the man at the door announced, "Alcohol, Tabacco, Firearms," I naturally assumed he was making a delivery.
Old 08-25-2014, 7:00 PM
russellmaher's Avatar
Nice and clean setup. Well done.
Thanks for sharing.
Russell
SEMPER PARATUS
BCD436HP HP-1 BCD396T BCT-7 BC350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050 TDXone TD-Q8A YAESU FTM3200DR FT70DR
Old 09-05-2014, 10:11 PM
Super nice and clean... Love it !
You be steppin....I be stomping.
Old 10-29-2014, 4:33 PM
JimmyL1011's Avatar
Hey FM2150....where'd you get the racks you use to hold your radios? Looks pretty sweet. I could use 4 to keep misc radios. Inquiring minds wanna know.
JimmyL1011
Old 10-29-2014, 4:53 PM
03msc's Avatar
I'm not the OP but check this link on ScannerMaster.com:
Home and Comm Center Brackets and Mounts for Police Scanner | ScannerMaster.com
Old 10-29-2014, 5:17 PM
iMONITOR's Avatar
Thumbs up
Looks great! Very compact, yet fully functional. I like those 3-tier stands. I have one BCD996T, and two BCD996XT's...tempting!
HTML code is On
