Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 10-04-2017, 6:52 AM
Ravenkeeper's Avatar
Default 2015 Chevy Silverado LTZ Z71 - Center Console
I placed my Uniden PC122XL and my Realistic scanner in the center console of my '15 Silverado. Other than the picture attached, others can be found in another thread that I started, for troubleshooting, at https://forums.radioreference.com/cb...no-static.html .
Since the pictures were taken, I have shifted my radios to the left side of the bracket, temporarily took the right angle adapter off the antenna mount bracket (replaced with original straight one), and am actively looking for the spring that I use to have when I had this setup on my 2010 Ridgeline. More pictures to come, when I finish getting it all set the way I want it, in next few weeks. I need to repair the right angle adapter, find my spring, put foam around the radios (keep food and crap from around them), and tune my antenna.
Old 10-04-2017, 3:33 PM
W8RMH's Avatar
Watch for overheating.
Old 10-05-2017, 7:22 AM
I'll keep an eye out for it. May tie a couple of fans into the sides of the console to blow air in/across/out of there.
Old 11-02-2017, 5:07 AM
Default Found the damn spring!!!!
I have found the spring, installed it, and re-installed the 90º for the mount bracket (after I fixed it with a couple drops of solder). Will post new pictures, after I tune the antenna and install some foam around the top (to keep food and crap out of where my CB/scanner are sitting), later today.
Old 03-16-2018, 10:51 PM
Angry Update: One Problem After Another
Just realized that my "My Radio Setup" album was "not public," so if you look at my profile, you can now see what I have been up to, to get back into the hobby of CB radio.
Since my last post, I tuned my antenna (wrong configuration, bed sidewall included), did A LOT OF RESEARCH as to why my SWR was about 2.5:1 across ALL 40, reconfigured my antenna, discovered that the Mini-8 connector on the antenna cable was SHOT (making/breaking), bought a replacement (unfortunately, I could NOT find anything other than solder-less), and found out (on the way home from that purchase) that my antenna was laying back 45+º at highway speeds. My son and I are going to do a few things around the house tomorrow, and if it does NOT rain (as forecasted) then we will replace the connector and re-tune my antenna. And if it's still not raining, I'm going to slave my footwarmer in-place of my SWR meter.
Old 07-10-2018, 7:59 PM
Angry Getting a “Do Over,” With NEW Truck
Unfortunately, I was a victim of a NON-contact HIT/RUN, Head-On Collision, on 01 July 2018, on Tehachapi Willow Springs Rd. Cellphones weren’t reaching, neither was my CB. New truck will have to wait until I’m healed up, broken foot, bruised belly (steering wheel), airbag burn, and bruised skull. Wife & kids are fine, some seatbelt bruising, wife & daughter have bruised sternums, and son has a bruised rib. Going to find a way to function check both my CB and my scanner, before I start lining up replacement antenna cable and how I’m going to route everything.
REPORT OF COLLISION - NEWS RELEASE | News | desertnews.com
“Desert Raven” 111
Antelope Valley, CA
Old 07-11-2018, 12:11 AM
mmckenna's Avatar
Wow, glad to hear you and your family survived. Sorry to hear the other guy didn't. That's gotta be a traumatic mess for everyone involved.
That was a nice looking truck.
Old 07-11-2018, 4:47 AM
krokus's Avatar
That was a significant impact. I am glad that you had not gone anymore to your right, or the injuries could be worse.
Sent using Tapatalk
Old 07-11-2018, 10:08 AM
Sent using Tapatalk
I was trying to get into the turnout, on the curve, to avoid the accident.
“Desert Raven” 111
Antelope Valley, CA
Old 07-12-2018, 5:33 AM
tunnelmot's Avatar
From a former AV resident and fellow radio enthusiast, I am glad you and your family are alive. A very tragic incident that could have been worse. Family is the most important thing. Please be safe out there!
"Stay...off...the...R.O.V.E.R"
HTML code is On
