Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Pictures Of Your Shack/Mobile Setup
Pictures Of Your Shack/Mobile Setup - Here you can post pictures of your shack, mobile, or portable setup for everyone to be envious of. Don't forget to rate the threads of good setups. Equipment installation questions belong here: Radio Equipment Installation
Old 05-10-2018, 1:06 PM
SimpleSkye's Avatar
Default 2012 Ford Fusion 3-Radio Setup
Consists of the following:
2012 Ford Fusion Sport
VHF XTL5000 (Laird BB1360WS 136-174 Wideband VHF Antenna)
UHF XPR5550 (Laird ETRAB4503 450-470 Phantom Elite Antenna)
7/8 APX6500 (Laird ETRAB7603 760-870 Phantom Elite and Laird GPSU15M GPS Antennas)
PanaVise 12" Stay-Put Flex Mount
All the control head wiring is under the carpet. The speakers are on the firewall of the passenger footwell. The VHF mic is run directly to the radio deck in the back. Apparently, you can't do that with the APX series, so I had to plug the extension directly into the front. Not as clean, but better than nothing. The XPR mic is also head-based. I ended up anchoring the flex arm to the side of the center console so it wouldn't wobble.
Ford Fusion Ham Radio
I have a sunroof, so most of the antennas are on the trunk.
A buddy of mine made the brackets for the control heads and seat mount.
I was a little concerned about the SWR for the VHF on the trunk, but it swept around 1.5 or better from 144-174. The others swept around 2, which is normal for the Phantoms.
Old 05-10-2018, 1:23 PM
mmckenna's Avatar
Looks nice.
I've had really good performance from the 1/4 wave antennas on VHF. I'm running Larsen NMOWB's on my personal and work truck. I'm seeing similar SWR curves as yours.
Old 05-10-2018, 1:34 PM
Will001's Avatar
Beautiful setup!
HAM Radio Call: KN4IMX
GMRS Call: WQYT-477
I own too many radios to put in the signature
=a bad day for scanner enthusiasts, and also a bad day for public safety...
Old 05-10-2018, 1:47 PM
ka1njl's Avatar
Default Wow!
That is a great install. It's neat and the control heads of all of the radios are easily accessible. Nice job!
FT-920 | IC-7300 | IC-7000 | FT-100 | Flex-3000 | BCD-996XT | BCD-436 | IC-7100 | AR-8000 | DJ-X2000 | ID-51A | IC-R30
Old 05-10-2018, 2:00 PM
norcalscan's Avatar
Nice install! Norcal representing with some real radios and real antenna mounting. My wife's car is a newer model Fusion so we have the odd storage scoop pocket in the front dash that some here squeeze in a small VHF, but alas no radios allowed anyway. I'm relegated to HT and magmounts if we use it on any trips. When the 700 system comes online you'll be ready.
Old 05-10-2018, 6:12 PM
Dann's Avatar
Very Nice....
Scanning South West Washington And The Portland Metro Area
Old 05-11-2018, 2:34 AM
WatnNY's Avatar
Impressive! Very well done.
Scanners: BC250D, BCD536HPx2, 996XTx2, 996P2, PRO-92
Ham: Icom 208H; Kenwood TM-V71; Hytera MD-380
Pro: Icom F5061; Kenwood 5210, 7180 & 8180; Motorola CDM1250, XPR4550x2, XPR6550, XTL2500
Old 05-11-2018, 10:40 AM
SimpleSkye's Avatar
Default Thanks!
Thank you everyone for your kind words!
Edit: I ment to say that the APX microphone is plugged into the head since it won't work if you plug it directly into the TIB.
Yeah! At the rate it is going, it will be second half of next year before anything is turned on; Chico hasn't even broken ground yet! A few of "us" have the APXs installed in our POVs, a couple others are kicking the tires...
Old 05-11-2018, 11:07 AM
The control head bracket, did you fabricate it, or was that something off the shelf purchased?
Very nice install. My preference is always to mount antennas on the roof, but with the sunroof that complicates things.
Interoperatablity is not a technology, it is an attitude!!!
Old 05-11-2018, 11:25 AM
SimpleSkye's Avatar
A buddy of my fabricated it; I can probably get the SolidWorks file he made if you are interested.
I agree roof mounted antennas are the ideal way to go. The performance doesn't seem to have suffered and it is much lower profile this way. I was really surprised that the sweeps were so good; I thought we were doing something wrong, so we moved the antennas to the roof of a SUV and re-swept them with near-identical results. The VHF antenna doesn't hit when the trunk is open. Plus, the wife said "It looks nice." and still likes to drive it around!
Ford Fusion Ham Radio Antennas
Old 05-11-2018, 12:01 PM
crazyboy's Avatar
You could wire it into the rear accessory connector. Great install though.
Old 05-11-2018, 12:06 PM
They will be somewhat directional on the trunk lid especially on VHF. Likely not a problem until you start getting a ways out from the repeaters. It will be noticeable when working simplex.
Old 05-11-2018, 12:20 PM
SimpleSkye's Avatar
Thanks! I don't know how I would get the GCAI connector to plug into the accessory connector. I can't find an adapter or cable anywhere, and I don't really want to cut up a $50 extension cable either...
Old 05-12-2018, 1:01 AM
RodStrong's Avatar
Nice setup.
Old 05-12-2018, 7:22 AM
crazyboy's Avatar
Yea, youd have to chop it up put pins on it and inset them into the accessory connectors.
Old 05-12-2018, 12:10 PM
Skypilot007's Avatar
Very nice. One question, does the control heads interfere with your passengers seat space? I was considering a mount like that but I frequently have passengers in and out of my car.
Old 05-12-2018, 2:33 PM
radio3353's Avatar
Very nice! So good to see people using commercial radios instead of the consumer crap (Whistler & Uniden) peddled today.
Old 05-12-2018, 4:06 PM
cmdrwill's Avatar
The connector pins ARE available separately.
Old 05-12-2018, 4:10 PM
crazyboy's Avatar
Not sure where anyone said they were not?
Old 05-12-2018, 5:08 PM
03msc's Avatar
I agree it's great to use commercial radios when you can. However, the scanners from Uniden and Whistler (which actually get pretty dang good reviews despite your claim of them being crap) definitely have their place as most people cannot monitor the systems they want to monitor with a commercial radio since they aren't authorized to do so.
Mark Arkansas
Uniden Whistler Kenwood Yaesu
HTML code is On
