I know this has been discussed before but I couldn't find anything for the particular setup I'm wanting to do so I'm going to ask as I want to do this correct the first time.
Hopefully sometime this summer I plan on mounting 2 more antennas on this building,
https://live.staticflickr.com/924/43137100211_897daad1cc_k.jpg
I will likely mount a mast to the left of the peak where the current antenna is now. About 8-10 feet to the left of the peak of the higher section is a 2x6 behind the vertical section of metal that I plan on securing a mast to, that vertical section is about 4 feet high, the antenna you see there now is 8Ft. high total. On the mast I want to mount two antennas, an Omni for VHF and a Yagi for UHF,
This is the Omni I would like to buy, I'll be receiving only at 160-162Mhz
https://www.theantennafarm.com/catalog/diamond-f23h-4865
And this is the Yagi I plan to use, and I already have it, I'll be receiving only at 942Mhz
902-17, 900-930 MHz
The VHF omni I plan to mount at the top of the mast, and then the yagi will go below it. The side of the building that the current antenna is mounted to pretty much runs straight E-W, and the yagi antenna will need to point NE, pretty much right over the roof of the higher left side. My questions are,
How high above the roof does the yagi antenna need to be as to not be affected by the roof, and then how much higher will the omni antenna need to be above the yagi?
I plan to use galvanized conduit or pipe, what size do I need to buy at the suggested height for enough strength? Unless someone has a suggestion of a better material to use?
I only want to mount the antennas as high as needed as to not have them affected by the metal of the building. I know the more height the better, but this is my Father-In-Law's shop, and I want to keep the visual impact to a minimum, and I may need to go with a smaller VHF antenna because of that. I have to see if he will even let me do this project, but I need to know the height the mast needs to be to ask permission first. I would just mount them at home but this is a MUCH better receive site than I have at home.
Thanks for the input!
902-17, 900-930 MHz
