atco gas meters?
seanwg
bemasher
I did some poking around at all of the FCC applications by Itron for devices operating in the 900MHz ISM band and the following models use the ERT protocol:
100G, 100T-CP, 100T-HON, 100T-MS, 100TGGRD, 100W, 45ES-1, 50ESS, 51ESS, 52ESS, 53ESS, 60W, 80W-i, AMI4, AMI6, C1A-2 , C1A-3 , C2SOD, C3A-1H, CVSO-B, R300S2
Depending on how your utility has your transmitter configured you may or may not be able to receive SCM's from it. Battery operated transmitters are typically configured in wake-up mode which will only transmit when probed by the meter reader.
