Are you picking up those frequencies with your scanner or sdr? Those sticks can sometimes be inaccurate if not calibrated
Scanner... no SDR as of yet, hence not getting the SYSID... once updated, i will be able to check with my 436 using analyse. not sure of any other way.
My set up consisted of a BCD436HP running a conventional scan for links, a BCD75 for the same and removed antenna while on CC to make sure it was that exact tower, and DCD+ running both CC and alts with a Dtap'd PRO-2025 with ext. ant. (Old School) lol. I can pick this tower up from 50km away, but with poor decoding.(Still shows NAC FB (251)
I confirm the towers by both what is in the RRDB, Conventional Searches, adn the DSD+ setup. Tomorrow after work, i want to check another site out that is not in the DB.
Also, i just noticed the RRDB only shows 1 of the 2 Regina 800mhz sites... might have to spend a day there to locate them and get the bandplan down as well. Only issue i have is i dont have a dtap'd unit to do 800mhz yet or a SRD. lol
Cheers
