Originally Posted by DJ88
Does anyone know if distance and signal strength have anything to do with a digital scanner's ability to decode digital signals? The reason I ask is because I live in northern Ocean County New Jersey use a Uniden BCD996T with an outside discone antenna, and I'm having trouble receiving the Coast Guard New York VHF Repeater, 164.9125 (P25 Digital). I don't know exactly where the repeater is located, but I do know I am quite a distance away from it wherever it is. Often times I get the buzzing (motorboat sound) and when I can receive it, it's broken up and the voice is hard to understand. It kind of sounds like space aliens talking. I receive other P25 systems okay, the farthest one being about 20 mies away. Any input would be appreciated. Thanks.
So I am assuming that you're getting the signal consistently but the signal is too weak or too noisy to properly decode? You could try going to a higher gain antenna and that would likely help. The fact that you're already using an outdoor antenna means that you'd probably need to go the next step and get a directional antenna which, of course, is going to be a bit more involved than the omnidirectional discone, as it will only work with certain frequency ranges well and also if you want to get different stations you'd need a rotator.
You could try a preamp to give it a little extra boost especially if it's going through a long run of cable. Don't expect a preamp to be magic or anything, but if you're right on the edge it may be enough and it would likely be the simplest way to go.
