Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Project 25 Technologies
Project 25 Technologies Discussion forum for the Project 25 Standard and its related technologies
Old 08-11-2008, 08:11 PM
fireandems13669's Avatar
Send a message via AIM to fireandems13669 Send a message via MSN to fireandems13669 Send a message via Yahoo to fireandems13669
Default 6.25 Digital
I am now using Icoms IDAS 6.25 Digital in all my radios now.My question is will a Apco-25 Scanner be able to decode my communications.I know 6.25 and Apco-25 use diffrent techs. but I am not aware if a digital scanner will decode both?
KC2VHB
Old 08-11-2008, 08:19 PM
Send a message via AIM to fineshot1
No - no digital scanner can yet receive the 6.25khz format from any of the radio manufactures.
fineshot1
NJ USA
Old 08-11-2008, 08:28 PM
Thanks ..Good to hear lol
KC2VHB
Old 08-12-2008, 09:43 AM
n1das's Avatar
Exclamation
No P25 scanner will decode your communications. However, OTHER digital radios using the NXDN format can.
ICOM iDAS 6.25kHz and KENWOOD NEXEDGE radios in 6.25kHz mode will work with each other on conventional channels since they are both NXDN radios. If your iDAS radio system uses any of the trunking features, you'll be locked into ICOM's iDAS repeaters. While ICOM's and KENWOOD's NXDN radios are compatible with each other in conventional mode, the trunking formats are unique to each manufacturer.
If you don't want anybody else monitoring your comms, either don't transmit them at all (mind what you say) or use the voice encryption built into the NXDN format. The built-in encryption is only 16-bit encryption...not very secure compared to AES or DES but probably secure enough for many uses. Think of this encryption as the digital version of analog voice inversion scrambling. If you want it to be VERY secure, you'll need the AES or DES encryption option which costs $$$$.$$. Also keep in mind the 16-bit encryption built into the NXDN format without a doubt has a huge undocumented "back door" feature for the government to go around the encryption for legitimate purposes.
Good luck.
David Sterrett
Nashua, NH
Ham [HA] = N1DAS (2/1984)
GMRS [ZA] = KAE9013 (12/1992)
Old 08-12-2008, 11:23 AM
Ya Thanks for the info I knew that NXDN and IDAS are the same.I will not be using it in a trunking format.
KC2VHB
Old 08-12-2008, 02:27 PM
n1das's Avatar
You should be good to go then.
If you use the built-in 16-bit encryption, you'll notice it will be completely transparent compared to clear unencrypted digital. The NXDN digital audio quality will be exactly the same. There will be no degradation of the audio like there often is with analog.
When you're transmitting with encryption and anybody else listening with a NXDN radio (Kenwood or Icom) and doesn't have the key (16 bits, 32768 possibilities), all they'll hear is a buzzzzzz of digital noise and no audio. For anyone who tries to listen on a P25 scanner or any other analog radio, all they'll hear is the racket from the raw NXDN data.
Good luck.
David Sterrett
Nashua, NH
Old 08-13-2008, 10:59 PM
N2DLX's Avatar
Send a message via AIM to N2DLX
I gave W2SJW a quick demo of 6.25 kHz NXDN tonight after our Ham club meeting.
David, any idea when Icom is going to release the trunking/IP networking card for their repeater? I've heard Q4 2008 from a couple sources.
Oh, I also partially reverse-engineered the serial port protocol (PC Command & PC Command V2) used on the Icom NXDN radios. Can change channels, TX, and a couple other things all via serial control. Pretty cool..
Old 08-25-2008, 04:21 PM
n1das's Avatar
Cool
KENWOOD has updated their website recently. There's more NEXEDGE (NXDN) product info there.
There's also some digital vs. audio samples to play. (I'm @ work right now, can't play them here.)
http://nexedge.kenwood.com
David Sterrett
Nashua, NH
Old 08-26-2008, 11:18 AM
Texas DB Admin
Not sure about when Icom will have any networking out yet (they promise and promise) but Kenwood does have trunking and multi-site trunking available. Only works with the Kenwood radios though. There was a difference of opinion on where the market was headed with 2-way radio. Icom wanted to start simple with an LTR-like digital trunking system, and then make it multisite. Kenwood started off with a full-blown MPT1327-type digital multi-site system.
Old 08-26-2008, 04:12 PM
So this is a few months old
http://www.icomamerica.com/en/media_...aspx?id=200807
http://www.icomamerica.com/en/produc...0/default.aspx
Above is the repeater fr trunking and net working
KC2VHB
Old 09-17-2008, 02:51 PM
I think so. Uniden has a digital, only digital scanner to copy the APCO25, and, I cannot remember more, but, it looks good! Anyway, I don't need it here.
Well, now I'm gonna turn off my laptop coz a turning off of lights and all here.
Greetings!
Old 09-17-2008, 06:51 PM
Originally Posted by stickair View Post
I think so.
Wrong. Apparently you did not read the earlier responses.
Wrong again - What happened to the GRE and Radio Shack(Actually GRE) digital models????
fineshot1
NJ USA
Similar Threads
Are you tired of spending $500.00+ for a digital scanner? OmensEdge General Scanning Forum 101 06-04-2008 02:14 PM
Digital Testing in Tulsa GlacierClipper Oklahoma Radio Discussion Forum 5 02-06-2006 12:45 AM
Digital Comms Matt_45 General Scanning Forum 6 04-30-2005 04:13 PM
Yuma Public Safety TRS Thunderbolt Arizona Radio Discussion Forum 2 12-01-2004 09:52 PM
