Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Project 25 Technologies
Project 25 Technologies Discussion forum for the Project 25 Standard and its related technologies
Old 10-05-2008, 07:09 AM
Default XTS 2500 alternative?
Our reserve unit uses XTS 2500's. 800. We are looking for a less expensive alternative than the Motorola (though still compatible with the existing system of course). We are willing to sacrifice some of the bell's and whistles if necessary. Can anyone point me in the right direction? Perhaps another manufacturer, lower end model, etc, etc. Thanks for any help you can provide.
If you can't stand the waves, learn to surf.
Old 10-05-2008, 07:18 AM
Send a message via AIM to fineshot1
What "existing system" are you referring to? Can you provide a RR link to it or describe its parameters?
More info is needed before anyone can answer a question such as that.
fineshot1
NJ USA
Old 10-05-2008, 09:05 AM
Send a message via AIM to KS4VT
The MT1500 is a carbon copy of the XTS2500 except that it is only available in analog and limited to 48 modes:
http://www.commdirect.com/downloads/...0_brochure.pdf
Instead of the MT1500 there is also the XTS1500 that allows for digital....
http://www.motorola.com/statichtml/X...008406b00aRCRD
Both are less expensive than the XTS2500 but without knowing the details of the system, like Fineshot pointed out, this is only preliminary imformation that you can use.
Old 10-05-2008, 09:46 AM
Texas DB Admin
An EFJ 51LT can be had for a lot less than the XTS2500. Still has all the bells and whistles, works on P25 Trunking, Analog or Digital SmartNet/SmartZone.
Will also charge in the same chargers as the XTS radios.
Old 10-05-2008, 02:38 PM
Sorry, should have painted a better picture.....
Take a look at: http://www.radioreference.com/apps/db/?sid=2684
System Name: Jackson County
County: Jackson
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Old 10-05-2008, 03:21 PM
OK now what do you need? Analog or digital?
Old 10-05-2008, 09:34 PM
digital
Old 10-05-2008, 11:50 PM
Seņor Member
How would the programming work? Would he need to order software? I'm assuming Motorola CPS won't work on an EFJ.
Old 10-06-2008, 07:36 PM
digital
Then forget about the MT1500 and the XTS1500 would be the next lower tier down.
I have seen them available on some past contracts for around $1300.
Old 10-06-2008, 07:38 PM
Yes he would need EFJ software, programming accessories, and system key. The EFJ system key is different than the Moto key and is much harder to obtain as you must have an original letter from the system owner.
Old 11-03-2008, 11:10 AM
W2GLD's Avatar
Send a message via AIM to W2GLD Send a message via MSN to W2GLD Send a message via Yahoo to W2GLD
My personal opinion is to stay with the Motorola's as they are manufactured to the VERY best specifications out of all the manufacturers...
However, should you choose to look at other vendors there are several: EF Johnson, M/A-COM, Vertex, ICOM, Harris, and Thales that make P25 compatible radios...
If you use SmartZone or SmartNet trunking, then you choices are a bit more limited to: EF Johnson, M/A-COM, Harris & Thales...
Stay with Motorola man, they are a little more expensive but can you really put a price on someone's life safety???
Good luck brother in your search for a cheaper radio, I think you'll find the pricing to be about the same across the board for the most part...
Regards,
Jerry - W2GLD
Old 11-03-2008, 01:37 PM
Jerry - W2GLD
Un No.. he said he uses Type II SmartZone so his choices are only Motorola or EFJohnson.
Old 12-03-2008, 07:41 AM
Stick with the Motorola, you can cut the option to make the radio cheaper and then add them later for a small amount. If you decide to go with the EF Johnson make sure you do a extensive test for a trunking system.
Similar Threads
XTS 2500 Digital alternative Kegan30317 Old Classifieds Archives 2 10-05-2008 09:13 AM
XTS 2500 charger Question Asmitty0010 Motorola Forum 3 08-06-2008 09:12 PM
xts 2500 question (scan problem) army_scanner Motorola Forum 5 06-18-2008 11:47 AM
WTD: Motorola XTS 2500 UHF 450-520 npd155 Old Classifieds Archives 0 11-30-2007 06:10 PM
Looking For Xts 2500 Or Xts 3000 450-512 Mhz IRONS826 Old Classifieds Archives 3 02-27-2007 03:01 PM
