Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Project 25 Technologies
Project 25 Technologies Discussion forum for the Project 25 Standard and its related technologies
Old 10-16-2008, 07:47 PM
underlift's Avatar
Default NXDN Programming?
Has anyone here set up a NXDN system yet? I'm Curious to see a Sample set up, Its Suppose to be somewhat like a Normal LTR Trunked system but I Here that there is Something Called system key, Unlike /\/\'s, would anyone have a Sample setup that they would be willing to share?
Thanks Al
Don't ASK, Its Best not to Know !
Underlift / AL
Old 10-16-2008, 07:58 PM
fireandems13669's Avatar
Send a message via AIM to fireandems13669 Send a message via MSN to fireandems13669 Send a message via Yahoo to fireandems13669
The programming is not complicated what are you looking to see I have a program file with me system on it
KC2VHB
Old 10-16-2008, 08:21 PM
underlift's Avatar
Hi, I Just wanted to see how system set up looks like programmed and user ID's for the Digital trunking, I have the software but it didn't come with any Sample setups
If you could send it to me i would be grateful
thanks al
Underlift / AL
Old 10-16-2008, 08:24 PM
Oh ok I dont have the trunking system so i wont be able to help there
KC2VHB
Old 10-16-2008, 08:50 PM
underlift's Avatar
So then you would have no idea of the System key that is required to program a digital trunking system that i was talking about?
Underlift / AL
Old 10-17-2008, 12:59 AM
N2DLX's Avatar
Send a message via AIM to N2DLX
I'm guessing you have Kenwood NEXEDGE radios, which apparently already have trunking available. To the best of my knowledge, Icom hasn't released their trunking capabilities. So you'll need to find someone who has the Kenwood radios, if that's the case. Last I heard, sometime before the year is out, IP Networking and Digital Trunking will be released by Icom.
Old 10-17-2008, 01:28 PM
underlift's Avatar
Well I Ordered the Radio (N800) Low Split (400-470mhz) but they aren't available Yet, So I switched to the high split (450-520mhz), I Purchassed the Software to play around with, To my surprise This Software wont program the low split UHF NXDN. In Order to check out the NXDN on the software, you have to make a system key, thats why I'm asking if someone has a sample set-up that I could view how and what you need to program the NXDN,???????
Any Ideas?
Thanks AL
Underlift / AL
Old 10-22-2008, 12:47 PM
LTR LTR is offline
I just received 2 new NX-300-K2 radios, so the 400-470 is now available, you must of just missed the new release when you ordered yours. Also, the software I got will program both low and high split. It has both 400-470 and 450-520 as selections listed under Model - Product Information.
In looking at the software, you only need a system key if programming trunking. Although I have not done anything with these yet, it looks like you can program conventional NXDN under the conventional system.
Old 10-26-2008, 08:32 AM
underlift's Avatar
The Software I Have is KPG-111D Ver 1.21 under the Model- Product Information, it only has 450-520mhz.
on my Software. What Version is Yours?
Have you tried to get into the NXDN Trunking?? It should say Something about "System Key Reqired" (That is Only Available with the Service Managers Software), I tried to Order it from the States But the Dealer there couldn't find it. I Believe it should be KPG-110SM????
Has Anyone Come Across That Software or know Anything about it????
Thanks AL
Underlift / AL
Old 10-27-2008, 08:58 AM
Texas DB Admin
The only way to order the KPG-110SM (which is a copy of the software along with a separate CD containing a system key file) is to actually own an NXDN trunking system. Kenwood will only sell the SM version with system key to a customer that purchases a system. This includes dealers. There is a lot of protection on these keys to make sure that not just anybody can get one and program up radios on NXDN, MPT-1327, or P25 Trunking with Kenwood radios.
The KPG-110SM software is the exact same package. If you had a file that contains trunking info, you can view it, but just like Motorola, you can't make any trunking changes without the system key.
The programming is a lot like MPT-1327. If you have specific questions, PM me. Hope this helps.
Old 10-27-2008, 01:05 PM
LTR LTR is offline
My particular version of programming software is 1.31, so it is newer.
I currently just have mine programed for conventional NXDN since I do not have a system yet.
Old 10-30-2008, 08:52 AM
underlift's Avatar
I was trying to purchase the NX800 Radio 450-520mhz since the software that I purchased only would program that Range and either radio could handel the frequencies that I Needed, but for some reason the Canadian Authorized Dealer said that he could only order the 403-470mhz (Canadain version) from Kenwood, If Kenwood sold me a Version that was updated less than a Month later, Do they Not Send a Update of the Software????? The Place that I Purchassed the Software in the USA sugessted to try to Hook up the lower Range Radio to see what happens when I try to program a Radio that is out of range for the Software, But I have to wait untill I get the New Radio that I Ordered.
Also for the Conventional NXDN is the Used or Group ID set up the Same as Normal type Conventional ID's???????
Thanks for any Help
Underlift / AL
Old 11-03-2008, 10:15 AM
LTR LTR is offline
I do not believe Kenwood charges for any updates as long as you purchased the original software from an authorized dealer. Have your dealer check their "special" dealer website for an updated version.
The conventional NXDN is set up similiar to a conventional analog channel except you use a "RAN" code instead of a CTCSS or DCS code.
Old 11-04-2008, 05:27 PM
underlift's Avatar
Thanks for he Info
Underlift / AL
Similar Threads
Kenwood TK-790 Programming Cable ECHO3 Old Classifieds Archives 8 09-20-2007 06:19 AM
Programming software to control a scanner Gilligan Scanner Programming Software 5 01-19-2006 11:24 PM
2096 Programming pcfn360 Radio Shack Scanners 0 11-24-2005 08:09 AM
