Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Project 25 Technologies
Project 25 Technologies Discussion forum for the Project 25 Standard and its related technologies
Old 01-28-2009, 10:05 PM
Default Someone explain Fall Back In-Cabinet Repeat
Ok on my Quantar's there is an option for Fall Back In-Cabinet Repeat which is enabled. And the Fallback Timer is set to 500 msec.
Now if the base station losses it's wireline, what does this exactly do. As of right now, I see that it does absolutely nothing.
Can someone give me a little more detail into this.
Old 01-28-2009, 10:36 PM
Default In Cabinet Repeat Option
This is most likely used when the audio/digital transport (microwave, leased phone lines, hard lines) are interrupted between the repeater and a analog/digital voting system. The repeater will activate a "relay/switch" to "loop" the audio/digital internally vs. sending the audio/digital to the voters and then the voters "voting" the best audio/digital signal. Once the best signal is determined by the voting system the audio/digital is sent back to the repeater/s.
I am not 100% sure but I believe you would need to have external audio/digital in/out enabled on the repeater to notice any difference.
Hope this helps.
Old 01-28-2009, 11:22 PM
N_Jay's Avatar
Probably so a duplex base/voted repeater, will default to in cabinet repeat if the line or the voter fails.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Similar Threads
Sticky Thread for MilAir II TinEar Maryland Radio Discussion Forum 4098 01-01-2008 11:21 AM
Sticky Thread for MilAir TinEar Maryland Radio Discussion Forum 2734 11-10-2006 06:51 AM
A.A. FIRE REPEATERS NINN27 Maryland Radio Discussion Forum 22 08-05-2004 08:56 PM
