P25 signal strength
A new P25 700/800Mhz system is being installed in Chattanooga, TN, that will overlap the current mixed-mode SmartZone system. It's on the air now and a new master controller, or "brain," is actually contolling the mixed mode and P25 systems. There are four simulcast sites with additional stand alone sites to provide coverage in a large region.
Anyway. I have noticed that the P25 control channel signal strength varies, as if the transmit power level is wobbling up and down. It peaks full bars, then goes down to two or three. This is the four-site silmucast part. Is this the nature of P25, to see such fluctuations in signal stregth? The analog system shows a rock solid signal strength.
A new 700MHz stand alone site was just put up and it too has a fluctuating signal strength.
Could this be the system is not at full power yet and is undergoing fine tuning to synch times/signals? It's been less than a month on the air. My Uniden 396 does decode the audio very well at 0% error rate when the techs test this.
Should a P25 trunked system show a solid signal strength?
Curious,
BG..
ButchGone
