Originally Posted by N9JIG
On a true P25 system, such as the Michigan, Illinois or Colorado statewide systems, does each site have a limit of 3 available Control Channels, or could there be 4 like 3600 baud Moto systems? So far I have seen Sites with either 1 or 2 "Alternates" in addition to the current "Control" channel, but never with 3 Alternates.
Yes, there can be a maximum of 4 control channels.
Also, are the Alternates merely control channels that just are not in use at that time for Control? That is, if the Control Channel switches to an Alternate, would the original control channel then be labeled as an Alternate and the new Control Channel be labeled as such or would it remain as an Alternate, even though it is currently the active Control Channel?
Like a lot of questions about trunking, the answer is - it depends.
Motorola seems to like to ship the systems with the four control channels set with priorities from 1 through 4. A priority 1 control channel is the main one, if it fails, the #2 one takes over. If the problem was temporary, it goes back to the #1 channel. I'm guessing it would take something rather interesting to cause the system to have to use the #3 or even worse #4 control channels.
The setting can be changed so more than one channel are at priority 1. in that situation, if the active priority 1 channel experiences even a momentary "burp" the other priority 1 channel takes over and things stay that way until there's a reason it has to let go. Only then would the original control channel get the job back (assuming the system thinks it's ok to let it take over again).
