Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Project 25 Technologies
Project 25 Technologies Discussion forum for the Project 25 Standard and its related technologies
Old 02-03-2012, 10:59 AM
Default P25 Phase II Questions
What is the difference between the two phases? Will Phase I be phased out eventually and Phase II taken over?
Is the audio quality any difference in Phase II? Thanks!
Old 02-03-2012, 06:17 PM
Phase 1 support 25Khz/12.5Khz channel spacing. Phase 2 support the future spacing of 6.25khz.
Old 02-03-2012, 06:45 PM
Seņor Member
Phase two allows two slot TDMA on a traffic channel. That's two independent conversations. The voice channels may be mixed Phase 1 compatible voice channels interleaved with Phase 2 channels. Control channels are essentially the same.
Possibly. All Phase 1 radios would need to be upgraded or replaced.
For simplicity, interop and mutual aid channels might stay Phase 1.
Old 02-04-2012, 08:14 AM
Not quite - that was the sales message from Motorola and the TIA in the early 90's which was based on a dream that future advances in electronics would allow them to meet their targets inside a 6.25khz channel.
It seems that either the state of the art in electronics isn't what they expected, or the laws of physics intervened, so P25 Phase 2 is actually 6.25kHz "equivalent" meaning that 2 slot TDMA inside a 12.5kHz channel was require to meet the targets of phase 2.
A P25 Phase 2 channel still requires 12.5 kHz of RF bandwidth no matter how you look at it.
Cheers,
Matt
Old 02-04-2012, 11:07 AM
Seņor Member
Clock accuracy is a problem at 6.25 kHz.
A 600 Hz error at both ends at 12.5 kHz is tolerable. Not so at 6.25 kHz.
Old 02-07-2012, 08:21 PM
Wink
If you have not already, you may also want to read the posts below this one regarding Phase II mixed mode FDMA/TDMA. Don S provides an excellent explanation
Old 02-27-2012, 03:20 AM
dont know much about p25 but are there any scanners that can recive p25 phase two in the market
Old 02-28-2012, 12:41 PM
Red face
No. The GRE PSR 800 can decode X-2 but not Phase 2 TDMA. Does the 800 have the correct hardware to decode Phase 2 TDMA via a frimware update? Right now that is the $400 question.
Old 02-28-2012, 09:52 PM
thanks was considering buying a gre 800 but im not sure if i should wait for the 900 thats supposed to be coming out this year
