Mike_Alpha
I just received my ARD25 Apco25 decoder and I'm very disappointed with it's performance with the AOR AR8600. I've done the all mode IF mod and although the AR8600 does scan, the width of the 10.7MHz IF output is just too wide to be used on frequencies with 12.5KHz spacing.
The ARD25 cannot filter out the adjacent signals to the frequency being monitored and the slightest bit of interference disrupts the digital decoding. Also, while the AR8600 is scanning or searching, a sound similar to a horse galloping comes out of the speaker. It also stops on any interference signals caused by adjacent channel activity up to 50Khz away.
The audio from any analogue transmissions that go through the ARD25 are distorted with bad clipping. I'm thinking that the IF output level could be too high and overloading the front end of the ARD25. But you'd think AOR would have matched the signal level between the units. I might try an attenuator in line and see if that helps.
I read somewhere that the SCAN-L guys have got the ARD25 to work with other scanners using a 10.7Mhz IF. They also said they have got the decoder working with a discriminator output signal. I have not found any information on the net regarding how the discrimintor signal is input to the ARD25.
If anyone has any suggestions or links to the discriminator input modification, please post here.
