I would like to install a discriminator tap on my scanner so I can use programs like Trunker and monitor other goodies that the Motorola P25 network transmits. Do I need to install the discriminator tap on my new $500 scanner to listen to the data on the networks?
I figure a cheaper scanner would work just fine assuming it can dial in to the 700MHz and 800MHz networks, even if the scanner doesn’t have built in decoding functionality, because the computer software is decoding for me. Am I correct?
If I’m on track with not needing an expensive scanner to install a discriminator tap to listen to raw data, what cheaper scanner is pretty reliable and easy to install a discriminator tap on?
Thanks for the help!
JD
JD
