Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Direction Finding Forum
Radio Direction Finding Forum Discussions regarding direction finding and transmitter location
Old 06-19-2009, 08:19 AM
Default New Adcock RDF idea
Over the years several Mfg's have made VHF RDF systems like the Regency Marine Polaris and I think Ramsey still makes one but this idea seems better. The idea is to use NMO hardware on small mag mounts. Supplied this way the consumer could buy whatever antennas he needed based on how much $ he could put into it. The antennas usually are proprietary which offers no option to antenna selection. I would be interested in an Adcock RDF type antenna if it had this feature. I tried to locate a good Polaris system but being 200 miles from the coast made it very hard. Ebay was out because of size of the Polaris antenna being shipped. SO, with hopes of someone reading this someway connected to the Mfg'ing of antenna systems is a long shot. Remember, lots of antennas are just made to SELL. A few select antennas are made to WORK. Best regards, Larry
Old 06-19-2009, 10:45 AM
DaveNF2G's Avatar
The accuracy of the system would be affected by antenna selection. All antennae must be identical, and their size and therefore radiation patterns must be calibrated to the element spacing.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 06-20-2009, 01:10 PM
None of those issues were disputed. Antenna selection would the the option of the buyer - not the seller. They would of course all be the same. The element spacing is controlled by the Mfg's assembly of cable and hardware. The idea is: I would rather use VHF 3db Gain ant's, or something else, in place of 1/4wave whips supplied by the Mfg. There are at least 200 antennas on the commerical market that use NMO. Thanks for your reply, Larry
Old 06-21-2009, 01:16 AM
DaveNF2G's Avatar
A gain antenna has gain because its radiation pattern is altered. A gain antenna will affect the system's DF accuracy.
Old 06-21-2009, 12:36 PM
I don't think a gain antenna has anything to do with the accuracy however the spacing between antennas and precise length of coax for a specific band does matter.
OAR sold a mag mount box with 4 whips for its mobile direction finding equipment so there are other designs out there.
prcguy
Old 06-22-2009, 10:07 AM
Default Omni-directional gain
For those who don't know where the gain comes from (I presume Dave already knows this), Imagine a normal quarter wave vertical antenna: It has a doughnut shaped far-field radiation pattern. Now imagine a gain antenna: It has a pattern of a flattened doughnut.
Dave, I understand your misgivings. Many gain antennas, such as a 5/8 wave, depend strongly upon having a good ground plane. Installing more than one of these things on a car roof could make for a less than omnidirectional pattern. But that would be the case with 1/4 wave verticals too. I'll agree that with gain antennas such as a co-linear array, there will be side lobes above and below the main lobe. This means that unless your signal source and you are relatively level, you might run in to trouble figuring out where something is coming from.
The concept could work. But you'd have to be very careful to avoid antennas with more than one element, and you'd need to be certain you've got a good ground plane underneath it. This is good advice for any Adcock array, not just one with gain.
Jake Brodsky, AB3A
Similar Threads
A crazy idea for a future scanner racin06 General Scanning Forum 16 07-12-2007 10:20 AM
New idea for Uniden data ports Gilligan Uniden Scanners 14 04-13-2006 01:38 PM
idea i had but dont know how to do it drew6553 Tavern Archives 7 03-31-2006 05:05 PM
Is digital voice over analog voice a wise idea. poltergeisty Tavern Archives 4 07-28-2004 11:47 AM
