prcguy
I picked up a newly released RDF at Dayton and it works really well so far except for the antenna heading pointing in the wrong direction. I had to reverse the antenna array on my truck to make it point correctly and the antenna headings are probably just mislabeled.
The antenna is comprised of five little mag mounts with female BNC connectors and you have to supply the whips or rubber duckies. You can move the mag mounts to optimize for VHF, UHF, 800, etc. You also need to supply a VHF/UHF FM receiver and once you get the volume at the right level it takes off and points like a bird dog.
Cost is only $300 for the non GPS enhanced version (which I got) and its display is a 36 LED circle that points toward the radio source and a three digit compass heading. The GPS version overlays headings on Google Maps and the more headings you add the more accurate it will point to the source on a map. That was $98 extra and I can add the GPS module later.
Check it out at: Radio Direction Finder DDF2020T - GLOBAL TSCM GROUP, INC.
prcguy
prcguy
