Go Back   The RadioReference.com Forums > Service Specific Monitoring > Radio Direction Finding Forum
Radio Direction Finding Forum - Discussions regarding direction finding and transmitter location
Old 05-31-2016, 1:42 PM
Default Helicopter DF to completely wrong location
Hello,
I was investigating a 121.5 emergency beacon that was going off near the Oakland Airport. We turned on our helicopters direction finder and followed the arrow until passing over a group of antennas on top of a mountain where the arrow would swing from the 12 o'clock to the 6 o'clock position (as it should). After 3 passes from different directions, we were very confident on the location of the source. We later found out that the signal was actually coming from a boat in a marina back near Oakland. I've been reading about radio repeaters and my onboard DF equipment and cannot figure out why this might have happened.
Has anyone experienced this before?
Does anyone have a theory on why this may have happened?
Is there anything I can do in the aircraft to try and counter future false readings?
-Sam
Old 05-31-2016, 9:31 PM
rfradioconsult's Avatar
What make is your DF equipment, Becker is pretty common for airborne use.
Old 06-01-2016, 3:41 AM
RFI-EMI-GUY's Avatar
If this is a doppler direction finder it is possible the antenna leads are swapped, and/or the calibration phase is off. Best to try DF ing a known transmitter and check that the display is calibrated prooerly. You may need to be airborne to make a proper check as ground reflections will confuse the antennas if belly mounted.
"Have Spectrum Analyzer, - Will travel" "Going Green"
Old 06-01-2016, 9:15 AM
Originally Posted by samiam1234 View Post
Hello,
I was investigating a 121.5 emergency beacon that was going off near the Oakland Airport...
-Sam
Welcome to RadioReference, and thanks for trying to help someone in distress.
Best Regards,
73 QDP
Old 06-01-2016, 11:52 AM
prcguy's Avatar
When passing near or over a mountain top repeater site I would expect many radios to become overloaded due the high RF fields and potential Intermod from equipment on the mountain or created in your DF receiver. I think most DF receivers are just glorified police scanners and don't do well in high RF environments.
prcguy
Hello,
-Sam
Old 06-02-2016, 4:41 PM
902's Avatar
902 902 is offline
I've been able to track an ELT in a 182 with a Becker pretty much dead-on - but I was nowhere near any TV or FM antenna farms at the time.
I'm with prcguy. There may have been an FM station, or a combination of very strong RF at a bunch of frequencies at that mountaintop site that was swamping your DF unit and providing a false reading. Good to know, if that's the case.
You might have tried with your com radio at a lower altitude to cut down on the footprint of the area you're receiving. I would say if you were in a fixed-wing aircraft, you might have tried some banking turns to block the antenna and maybe null out the signal, too.
These days, it probably pays off to cruise the airports and marinas first, although I've heard some wild stories from old CAP guys about chasing garbage trucks after people have thrown their ELTs out.
What kind of equipment do you have, Sam?
Old 06-02-2016, 5:57 PM
My suggestion would be contact a local CAP unit, you may be able to observe one of their practice ELT exercises. If you are affiliated with a Public Safety agency or Emergency Management, you may be able to setup a joint training exercise.
Old 06-16-2016, 10:19 AM
Hello,
-Sam
I will try and take a wild a** guess on this and say that there might have been a birdie coming from some transmitter there on the mountain. Doing some simple math, which might or might not come up with the correct answer, I have the following frequencies: 30.375 MHz., 40.5 MHz., 486 MHz. I am sure there are others, but these are the direct hits. Now there could be a transmitter on that hill that is just spilling out trash and generating a signal.
You might try listening to the 121.5 frequency with a receiver and see just what it sounds like. This would provide a hint of where it's originating from. The key here if it's on continuously, then that limits the sources. It could be an intermod hit that might involve a mix of two or more transmitters. If this is the case, good luck on locating what is causing it.
Jim
Old 06-16-2016, 1:01 PM
The DF is a Rockwell DF-301E. 100-400MHz.
Thanks for all the responses. All great ideas. I'll keep playing with it and let you know if I find anything else.
We we're listening to the beacon as we were looking for it. It was intermittent when we were far away (obviously), but as we got close the beeping was relatively consistent and sounded like other emergency beacons that I've searched for.
Old 07-11-2016, 1:02 PM
Assuming you are using a doppler direction finder and can listen to the output of the doppler receiver, listen for a pure tone from the doppler array.
If the tone is distorted you will not get a good direction reading out of it. It could have been hunting for a tone that was actually generated as intermod between the real signal and some other combination of things.
Rick
WA1NIC, WQAV-895, WPIH-815, PG0111912
Old 04-19-2017, 12:17 PM
Chronic's Avatar
Very well could be a reflection or reflected signal off of the mountain , this can also occur with tall buildings , metal structures , most anything the signal can bounce off of .
Tags
121.5
