Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-24-2008, 3:22 PM
Smile Inside house install
I need some suggestions from those antenna/install pros!! I cant put an antenna on the roof due to expenses and neighbor problems. Can anyone give me advice on how to install a portable antenna in the house to boost my signal?? I have the mag mount spectra, and several frequency-specific antennas. Any help would be appreciated.
Old 08-24-2008, 3:56 PM
KC0QNB's Avatar
Got an attic?
Yaesu CPU2500R, 2x Bearcat III, old PRO-46, and a new PRO-136. DX-399
Grid Square DN90WW
Old 08-24-2008, 4:06 PM
Negative on the attic. I have tried mag mounts on the radiator grill but no difference. i guess I am stuck with what I have. I was hoping to clip something outside the window for improvement but no such luck.
Old 08-24-2008, 4:24 PM
KC0QNB's Avatar
Can you open the window? if so I have an idea
Grid Square DN90WW
Old 08-24-2008, 4:26 PM
can you get on the roof??
Attach a ventenna to one of your vent pipes (spray paint it match the color of the vent pipe) nobody would ever know!!!
Old 08-24-2008, 6:33 PM
Yes,I can open the window!! Interested to know your idea!
Old 08-24-2008, 7:29 PM
KC0QNB's Avatar
you can get a base adapter for nmo type antennas, of course there are different models, make a bracket that attaches to the window sill.
Grid Square DN90WW
Old 08-24-2008, 7:43 PM
Default Will mounting in the attic really work
I was considering putting an antenna in my attic (probably the radio shack mag mount that I already own) will this really improve reception and if so how should it be mounted?
Old 08-24-2008, 8:21 PM
KC0QNB's Avatar
It will help but it will work better with a ground plane.
Grid Square DN90WW
Old 08-24-2008, 8:45 PM
If there is something up there that is big and ferrous, it could work out very well. Steel ductwork or an HVAC air handler have all kinds of possibilities.
I have used the front panel from a washing machine, others have used an electric football game as a ground plane.
Some posts can be interpreted in various ways.
Mine generally mean exactly what they say.
