Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 12-13-2008, 03:12 PM
Default Subaru Forrester
Has anyone mounted a radio in a Subaru Forrester? We're leasing one and I'd like to mount a TM-D700 radio in there.
Obviously, no holes.
And, it's my wife's car, so it needs to be as unobtrusive as possible.
Here's what the interior looks like.
Rob
N7LXI
Seattle
Old 12-14-2008, 12:37 PM
I don't see how you can mount any radio without drilling some holes somewhere.
Old 12-14-2008, 09:13 PM
By "no holes" I mean no huge brackets screwed into the dash or NMO antenna holes drilled in the roof.
Rob
N7LXI
Seattle
Old 12-15-2008, 12:29 AM
stateboy's Avatar
That starts to put it into the "Why bother?" category
Got WISCOM?
Old 12-15-2008, 11:44 AM
That's my point. If the radio is heavier than one of these handheld scanners, there's basically not a good way to mount the radio without drilling holes for a bracket of some sort. You will either have problems with the radio moving around too much, with it being too easy to steal, or some other issue. I tried attaching a CB to the lower part of the dashboard of a Chevy Celebrity, using velcro. It worked until I hit a bump and the radio crashed to the floor. After a couple of times of that nonsense happening, I undid my bright idea. LOL! I am not familiar with your radio, but if it is one of those with a detachable face, then you will have some options, like brackets that clip on to the vents.
Old 12-15-2008, 03:49 PM
You may recall the original post said:
"Has anyone mounted a radio in a Subaru Forrester? We're leasing one and I'd like to mount a TM-D700 radio in there."
I'm looking to hear from people who HAVE mounted a radio in a Subaru.
And the D-700 does have a removable face.
Rob
N7LXI
Seattle
Old 12-15-2008, 08:33 PM
wx4cbh's Avatar
I have mounted radios in several Subarus over the years including several municipal leased vehicles for public works people. The last one I did is the Yaesu 7800 ham radio in my granddaughter's 2008 Outback. As far as mounting a radio goes, Subarus are only different in the details from every other vehicle out there. If you can figure out how to do it properly safetywise and without putting a hole in anything, go for it.
You can try sticking the rough side of adhesive backed Velcro to the radio for mounting on a flat carpeted surface under the seat or such and putting a sufficiently sized tether to the seat frame or whatever other substantial anchor as a back up in times of the dreaded accident and flying objects. The carpet acts as the Velcro fuzzy side for the rough side stuck to the radio, and the anchor assures it'll stay where you put it. I used a piece of 1/8 x 3/4 strap bolted across the top of the radio mounting bracket and drilled a 1/4 inch hole in the seat bracket. Then I bent the other end of the strap to match the surface of the seat frame and bolted that through the 1/4 inch hole. Just make sure none of this interferes with the movement of the seat and that none of the wires get into the seal slide rails or latch/release mechanisms.
If you're going to mount the radio on a vertical surface with tape/Velcro/Twin Lock, try to keep it in a low, cool, well ventilated area and on a hard smooth plastic or metal surface so that the adhesive won't be so likely to give up in the heat and the radio can cool, but don't put it where it's in the way of your feet or loading just because the surface is right. You may also find existing bolts under the dash areas that will allow you to drill the mounting bracket to accommodate the bolt spacing, or you could use a combo of a bolt and Velcro. If the bolt is too short, hit a fastener store for the right lengths.
For the control head and mic, there are "vent mounts" and dash mounts that use either existing dash fasteners or adhesive mounts and may come with swivels, depending on how elaborate you want to get. Just remember that these vent mounts can make great collision targets for your face and other body parts if not located in a safe place, and some brands and varieties are worth far less that what you'll pay for them. Choose carefully.
You can mount any of the radio components with things like double sided tape or 3M "Twin Lock" or other types of adhesive mounting creations, but the combo of summer heat and the volatile oils in the vinyl dash surfaces will usually cause the adhesive type mounts to fail at an inconvenient moment if the entire weight is supported by the adhesive on a vertical surface. Ask me how I know. Down in the console area, adhesive foam tape works well if the head fits into a space where the back surface is tilted back a bit or is flat so that the weight isn't all on a vertical surface.
A heads up: most amateur radio lcd displays aren't visible from any angle that is much "below" the middle of the display angle, so if the head is flat on the console surface and is located so that the view is from what would normally be the bottom of the control head, the display may not be visible. I don't know if the 700 has a contrast adjustment to correct for this or not.
Antennas are another game. I have no use for a mag mount due to the fact that the cable is going to be compromised by a window or a door closing on it and magnets don't work at interstate highway speeds when combined with really gusty winds. Ask me how I know that. You could preferably use a dual band no-ground plane unit (Comet or Diamond would be a good place to start) on a bracket mounted at the hatch, but you're still dealing with passing the cable through the hatch opening. Luggage rack mounting may not provide sufficient ground or ground plane for the antenna to work properly, but at least with a no-ground plane type you have more options to work with in finding a sweet spot.
A lip mount on the hood could work with the antenna cable passed through the firewall at a grommet like the power wires, but keep in mind that the cable will have to be routed to protect it from underhood heat or the feedline will quickly become something other than 50 ohm cable. Ask me how I know that one, too.
One thing you won't be able to get around is the proper attaching of power wires to the battery. They've still got to go to the battery, and they've still got to pass through the firewall to get to the battery. Don't even think about skirting the manufacturer's instructions and using the half-assed cobbled-up method of trying to tie to the fuse panel or use a power port. Neither is designed to accommodate a transceiver's power requirements. I used an existing grommet by checking clearances first, then pushing a small Phillips screw driver through the flexy part of the grommet next to the harness to make a small hole for the power wires. The wires are run under the edge of the console and down to the radio through the seat frame in the space next to the seat belt anchors. The Forester may have those seat belt anchors located differently, but you get the picture.
Sorry to be so verbose and long in the post. Hope some of this helps.
PS: Forget the built-in speaker and get yourself an external speaker and find a place to mount it. You'll thank yourself for that.
Old 12-15-2008, 10:08 PM
lebrunmn's Avatar
Default My old Subaru Outback mount...
Not exactly a Forester, but the shifter area looks pretty close. Parts came from a site called:
Proclipusa.com
Hope the photos help.
Regards,
-Mark (KB3OAL / WPSK331)
BC796D w/ Remote Head | BCD396T | PRO-2096 | PRO-96 | BC250D | BC780XLT | PRO-90 | PRO-91 | TH-G71A | HT 1000 | VX-7R
Old 12-16-2008, 11:28 AM
Those are some great ideas. Thanks.
I'm thinking a proclip (as seen above) to mount the head, RF deck under the seat, lip mount NMO on the hood.
(FYI: I have 5 radios currently in my truck, but wanted something small for the wife-mobile. She's not exactly "pro-radio", so the more unobtrusive, the better.)
Again, thanks for the constructive help.
Rob
N7LXI
Seattle
Old 12-16-2008, 08:27 PM
Thanks for the pic. I did some checking around and found this vent mount. The site says it's designed to work with Kenwood radios, so this may be just what you need. The radio itself can be mounted under the seat, either by using Velcro (as has already been suggested), or you could make a custom bracket that utilizes the bolts used to fasten the seat frame to the floor.
http://www.cheapham.com/LM-100.html
Also, I don't have to be an expert in mounting a radio to be able to point you in the right direction. As I said in one of my posts, I am not familiar with your radio. I didn't know it was one of those with a detachable face. You can go to Eham.net to check out the reviews on this LM-100.
Old 12-19-2008, 01:09 PM
pdewees's Avatar
Check out QST article on using the glove box by mounting the radio to a piece of metal that hangs on the lip of the glove box. I used this for the courage clasic bike tour in rented vans and it works great highly movable but very stable in vechicle. I also use d700. Attached felt from walmart to the metal to prevent damage to plastic and secured radio mounting bracket with hex bolts from ace hardware.
Old 12-19-2008, 01:55 PM
icom1020's Avatar
I mounted my icom1020 like in my avatar in my 01 Foz, the rf box is under the seat, the remote head is loose under the 5speed stick, which I don't like so I too am looking for solutions. I have a Pro-197 mounted on the drivers side of the center console which is also not as roomy for my shift leg
Rob, I live south of you, maybe we can compare notes.
Old 12-19-2008, 04:37 PM
icom1020's Avatar
two of the radios mounted or laying in my 01 Foz
The Pro 197 had it's mounting bracket drilled into the side of the console. I tried the opposite side and the occasional passenger leg would block my reach of the radio
Old 12-19-2008, 04:54 PM
icom1020's Avatar
elbow bracket antenna mounts. With a sunroof, a roof mount is nearly impossible except at the very back of the roof line.
Old 12-19-2008, 09:49 PM
I wouldn't be able to mount a radio that way in my Neon. It would get in the way. I guess that's the price I have to pay for being a good looking fat guy. I hate it that the bench seat has been replaced in so many automobiles. It makes it tough to mount a radio, unless it has a detachable face.
Old 12-20-2008, 12:34 AM
icom1020's Avatar
I'm not a big fan of center consoles. I should of bought a Impala or a Crown Vic, but it does drive good in the snow and the mpg is better.
Old 01-01-2009, 01:57 PM
Default FT-8100R in 2001 Forester
I mounted a Yaesu FT-8100R in my 2001 Forester in a "no holes" fashion, using many of the techniques wx4cbh mentioned in his reply.
The radio body is mounted under the front passenger seat using the mounting bracket and Velcro that happens to stick to the factory carpet very well. Direct power from the battery was run to that location, it is fused at the battery and I found an unused hole in the firewall with a grommet in it to feed to power cable through. Ok, I guess that's the one hole, but its in a grommet and not the sheet metal...
The face of the radio is mounted in the center dash pocket/storage tray that I see you still have in a newer model Forester - that place where the optional gauge package goes on top of the dash. Radio Shack used to sell a car radio installation kit that came with lots of great brackets you could adapt for most installs. I used a couple of them to mount the radio face bracket with automotive double stick tape and then Velcroed again to the car surface, this time the interior of the dash pocket. The control cable was routed from the radio body up to the radio face along the center hump and then up the dash. The cable runs along the face of the dash neatly in a crease between panels for about 10 or 12 inches - looks like the design has changed for your Forester so that crease is no longer there.
I ran a mic extension cable from the radio face under the dash and over to near the hood release. There I connect in the stock mic and hang it on the drivers door - again with the automotive double stick tape.
I have a Diamond NR-770HB antenna mounted on a Diamond K9000LM motorized antenna mount (to fit in the garage) which is mounted to my luggage rack. The coax set I used has about 15 inches of RG-174 small diameter coax on the antenna end that allowed me to bring it in on top of the rear hatch weather stripping and then under an interior panel to be routed all the way up to the passengers seat.
All of this has been in operation for eight years without any problems, except for forgetting to lower the antenna a few times (clang!). No holes in any part of the car except the firewall grommet.
As a side note, I'm now planning a new install that will replace some of my gear and add some new stuff. I'm going to pull out the factory double-DIN stereo and put in a single-DIN HD radio and also a PRO 197 scanner. I'm going to change out the FT-8100R for a FT-7800R, and in the process clean up the radio face mounting. I have on order the housing for the optional gauge package (minus the gauges), to which I will fashion a mount for the FT-7800R (or the scanner, I haven't decided which will be up top yet). That housing is probably available for your model year as well if you want to go for a more integrated look. As it is now I can actually pull up the radio face from the pocket and push it back in the pocket and then close the pocket cover for security.
Let me know if you want to see some pictures of the install or if you have any questions.
Christopher NC6T
Old 01-01-2009, 04:13 PM
Dont forget to look up!!! What about an overhead console? ANyplace to mount a radio head there?
Similar Threads
Install 2004 Subaru WRX STi BCD396T & BC-RH96 KC0NYF Pictures Of Your Shack/Mobile Setup 56 06-18-2009 03:26 PM
Subaru Impreza 2007 trunkve Pictures Of Your Shack/Mobile Setup 21 08-11-2008 06:50 PM
Subaru Outback w/Remote Head lebrunmn Pictures Of Your Shack/Mobile Setup 12 10-16-2007 10:28 PM
06 Subaru Impreza - Top Gauge Pod mount - thoughts? Jay911 Radio Equipment Installation Forum 6 03-28-2007 07:18 PM
Subaru Impreza Radios dropkick Pictures Of Your Shack/Mobile Setup 36 03-27-2007 11:56 PM
Copyright 2010 by RadioReference.com LLC Privacy Policy  |  Terms and Conditions
