Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 03-29-2009, 03:06 PM
Default Base power supply
I need a cheap base station to get my radio system going right now. I am going to use a Kenwood tk-762H 45watt for the time being. I dont have a power supply for it but I was wondering if anybody knows if my idea will work, and safely. I want to know if using a small 12 volt lead acid battery and a 1.5amp battery maintainer. I will not be using it to dispatch or anything so there will not be much tx on it.
Old 03-29-2009, 05:20 PM
Your 45 radio will draw close to 10amps on transmit. While a small 12v battery will work, it will not work for long and at 1.5amps on the charger is going to take a while to charge. Even on receive your most likely near 2amps draw, so again its not going to last long.
Old 03-29-2009, 06:09 PM
James04TJ's Avatar
Not to mention that it is not a good idea to keep a lead acid battery indoors.
Old 03-30-2009, 09:12 AM
Send a message via AIM to fineshot1
As long as its a sealed lead acid battery it should be ok. All the new modern UPS systems use them and they are all inside a home or business.
But - getting back to on topic it would be best to use a proper power supply. They are not all that expensive these days. A 15Amp (or something in that range) should suit the purpose. There are switching supplies sold on ebay(or even possibly craigs list) in that range that should be relatively cheap and efficient.
fineshot1
NJ USA
Old 04-07-2009, 11:25 AM
Go to mpja.com. They have tons of power supplies there, and not very expensive. They're not "refined" desktop supplies; they're modules made for mounting internally into other equipment, so the AC input terminals aren't shielded. But you could easily put the p/s into a Rad Snax project box and have a high-current supply for cheap.
Similar Threads
FS:Icom 746 Pro and PS-125 Power Supply kc8ysl Old Classifieds Archives 1 06-05-2008 06:04 AM
Help with railroad frequencies. KC0QR Nebraska Radio Discussion Forum 14 05-21-2008 07:10 PM
Trains CLB South Carolina Radio Discussion Forum 4 05-13-2007 10:00 PM
Youngstown Convocation Center Schmetzy13 Ohio Radio Discussion Forum 1 11-08-2005 09:55 PM
Power Supply options - Too many walwarts! mikea7531 General Scanning Forum 26 05-04-2005 02:29 AM
