Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-07-2009, 04:33 PM
nyscan00's Avatar
Default Installation in Nissan Altima Questions
Has anyone out there done any scanner installs in a Nissan Altima? I have a '08 coupe and am looking to mount my BCT15 scanner. Figured I'd use the BC-RH96 remote head and possibly mount it somewhere near the console leaving the scanner to be mounted in the trunk. Not too sure on exact placement as the interior of the car isnt very scanner friendly. If anyone has any ideas or pictures from previous installs it would be a big help! Thanks!
Old 04-09-2009, 08:04 PM
W3MOT's Avatar
If you wanted to go discreet, you can do the remote mount inside the console somehow... If you want to do it the normal way with things showing, I'd try playing around with the little ledge thing just below the heating/cooling area on the dashboard. You could screw the mount in under the black part there... again, you could try but I wouldn't suggest anything on a brand new car like that unless you definitely know what you want to do. If you know what your doing, wires definitely wont be a problem with hiding because you could run the wires through the dashboard, down the console and through the floor and have the radio in the trunk or under the rear seats. Let me know if I could explain better.
Believe half of what you see, and none of what you hear.
Old 05-06-2009, 06:29 PM
I have a 2007 Nissan Altima. I cut my center console box underneath the A/C controls and have slid radio heads and switch boxes into that slot. I can close the lid for for "security" because I sometimes park near not so friendly neighborhoods. I went to my Nissan dealer to get a quick print out of schematic diagram of the console and part numbers and then I went online and found exactly the box I needed for $80 (much cheaper than from the dealership) with shipping.
Old 05-06-2009, 09:05 PM
b7spectra's Avatar
See if you can dig up some of the pictures of the new NYPD Altima's! They are going to start running about 40 of them if I recall.
/\/\|k.e
WQKM383
Support Your Local Search & Rescue Team - - - Get Lost!
Old 05-08-2009, 05:40 PM
nyscan00's Avatar
Thank you all for the info and suggestions. I bought a BC-RH96 head for my BCT15 and am going to mount it under the climate controlls on the console door that flips up. Figured it would be a neat clean install with the remote head. Plus can run all the cables behind that door - out of the way. Just want to order a spare console door to use as a replacement if I sell the car.
I'll be doing the install soon so when its done I'll throw some pics up.
Thanks again!
Similar Threads
2006 Nissan Altima GrumpyGuard Pictures Of Your Shack/Mobile Setup 14 09-07-2009 11:16 AM
General Questions... _DeS_ Eastern Canada Radio Discussion Forum 22 07-01-2009 07:21 AM
DPS questions for your serious DPSers... texasemt13 Texas Radio Discussion Forum 11 10-30-2008 12:52 PM
First time scanner user - WORTHY QUESTIONS Jon_in_Metairie General Scanning Forum 25 05-24-2006 08:21 PM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
