Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-07-2009, 04:29 PM
paramedszaf's Avatar
Send a message via AIM to paramedszaf
Default CPI Tone Remote(s) / ComTekk Software
Hey Everyone, there MAY have been a thread somewhere similar to this but what the hell anyway...
I am started in the early stages of working on setting up a back up communications set up.. I have found ComTekk's new version of their dispatch software to be pretty close to what I am looking for. My problem is even with reading the wiring diagram (ok illustration) I am trying to figure out how how to get point A to point B.. I obvously understand the Mic/Speaker/Aux part.. How the hell do I interface with the tone remote panels and the radios...
Any help is appreciated...
HT-1250 VHF
HT-1550XLS VHF
CDM 1550 VHF (mobile install)
CDM 1250 UHF (mobile install)
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 04-07-2009, 07:53 PM
n2hbx's Avatar
Default Tone Remote Help
First thing you're going to need is a four-wire phone line from the computer to the termination panel. You need one pair for TX audio/control tones and one pair to get the receive audio from the radio back to the computer. Thus, you need to make sure that the tone termination panel you select is capable of four-wire operation. Some are two-wire only. Using 600 ohm 1:1 isolation transformers on both pairs at the computer end is not a bad idea.
From the tone termination panel to the radio, you will need a PTT line, a TX audio line, an RX audio line, and a common or ground connection. How you connect these is going to depend on the radio you use and the termination panel you have. Some termination panels have prefab cables available to plug right into certain radio models. You may also have to do some programming in the radio to set it up for remote operation.
Once you have all the physical connections made and verified, the last step is to set the line levels. Typically you want your TX audio from the console (computer) to the termination panel to be at -10dBm, and the RX output from the panel back to the console (computer) at 0 dBm. RX levels generally aren't a problem, but too low a TX level and the radio will not key reliably or at all. Too high and the TX audio may overdrive and distort. The tone panel instructions will tell you how to test and set the levels.
I've been thinking about getting the ComTekk software and putting it on my laptop to use as a test set at work instead of lugging a tone remote around with me. Let me know how you like it once you get it working
So Many People To Annoy...
So Little Time.
Old 04-07-2009, 08:16 PM
Cat 5 ok? What type of connection to the computer? Serial?
Probably a CDM1550, can the radio be set up for every day use with a desk mic then hooked up when needed? I also have 2 M1225's as well is needed [/QUOTE]
Anyone have pics?
HT-1250 VHF
HT-1550XLS VHF
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 04-08-2009, 08:29 PM
n2hbx's Avatar
Default More Remote Stuff
Cat-5 cable is fine.
Your connection to the computer is strictly through the audio I/O jacks. The Com-Tekk software generates the control tones and sends them down the TX pair to the termination panel. In a sense, your PTT operation is like VOX operation because the tone panel hears the tones and provides the PTT to the radio.
Connecting to a CDM radio should be a breeze. You can use the accessory jack on the back of the radio to make your connections to the termination panel. Again, depending on the termination panel, you might find a cable already built that you can just plug in. There is also an Accessory Plug Kit that you can get from your local Motorola shop, or I've seen them on Ebay as well. You can connect a desk mic and use it normally; you don't need to unplug the tone panel from it. It will work just fine. The 1225 should work equally well. The accessory connector pinouts might even be the same....I'd have to check my manuals to verify that.
Just as an aside, be aware that the rule of thumb is no more than 250-300 feet for tone remote control (between the console/computer and the radio) regardless of what type of cable you use to connect them.
Larry
So Little Time.
Similar Threads
>> Various Scanner Software << jerneedog General Scanning Forum 47 03-11-2007 02:22 PM
fire tone-out info for Bexar County 396T users... muddy mudskipper Texas Radio Discussion Forum 13 10-15-2006 11:02 PM
FYI: BC796D SOFTWARE DEFICIENCY W4UVV Uniden Scanners 0 11-10-2004 10:58 AM
FYI: BC796D SOFTWARE DEFICIENCY W4UVV Uniden Scanners 0 11-10-2004 10:57 AM
Free Icom R20 Software released Butelsoftware General Scanning Forum 0 08-20-2004 06:38 AM
