Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 05-28-2009, 07:39 PM
APSN556's Avatar
Question Power mess... too many wall warts
I just recently acquired 2 more scanners. All work fine except now I'm faced with a unsightly and potentaly dangerous mess of cords and wallwarts. I have 3 power strips coming out of 3 seperate outlets and all are full to the max. Between 4 PC'c, 6 monitors, 5 base scanners, and a large shortwave receiver (Grundig 800) I am wondering if there might be a better way to manage my power. I also cant help but think that all these wires touching and crossing each other might be having an effect on performance of my rigs. Any suggestions?
Chad B.
APSN- Arizona Public Safety News Network- Arizona's premier incident notification network
www.apsn.us
Live Police/Fire/EMS feeds from Flagstaff, AZ
www.flagscanner.com
Old 05-28-2009, 09:56 PM
N_Jay's Avatar
The wires touching is no issue at all, crossing is less.
Get an 4 to 6 foot industrial outlet strip with all the outlets you need, or put together a few quad boxes.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 05-28-2009, 10:01 PM
seamusg's Avatar
Staples has a Outlet Extender (1ft.) #18301
Old 05-29-2009, 12:02 AM
APSN556's Avatar
I recently saw a post where someone was using and highly recommended using a device ( I cant think of the name of it) that was a strip that you could plug multiple radios into using the red and black wires (typically used for auto install. Does anyone know what I am talking about?
Chad B.
www.apsn.us
www.flagscanner.com
Old 05-29-2009, 12:19 AM
APSN556's Avatar
The thing i was talking about in my post above is called a RigRunner. So I have narrowed it down to two options. I either buy a RigRunner or a 12v Power supply. They both will run me in the neighborhood of $150.00
Does the RigRunner run from a wall outlet, or does it need a Power supply? If I get just the power supply, can I run all 6 scanners from that one supply?
Chad B.
www.apsn.us
www.flagscanner.com
Old 05-29-2009, 01:03 AM
I have a rigrunner and I love it.! It does not come with a power supply. I use mine for powering 5 motorola radios in "scanner mode" (receive only) with a 15 amp power supply - Thats more than enough power for receiving only. Scanners use very little power, around .5-1.0 amps i think. I would say a 10 amp supply would be more than enough for 5 scanners.
The only thing with a rigrunner is that they use Anderson Powerpoles for the connections, I love them, some people don't. They take a bit to get used to but they keep everything neat and safe. You would have to make your own wire/connections from your scanner (hardwire) from the scanner to the rigrunner but I'd say thats the only way to go if you really wanna get rid of the "wall-warts".
Let me know if you have any questions.
Alex
"Live Free or Die"
Old 05-29-2009, 06:27 AM
If the voltage for all your wall warts is the same then get a power supply and power the radio from one power source.
Old 05-31-2009, 08:50 AM
paramedszaf's Avatar
Send a message via AIM to paramedszaf
The RigRunner is the way to go. I agree getting use to the powerpoles is a PITA but WELL WORTH THE INVESTMENT!
HT-1250 VHF
HT-1550XLS VHF
CDM 1550 VHF (mobile install)
CDM 1250 UHF (mobile install)
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Similar Threads
Xcel Energy/MNPower in Duluth jdm911 Minnesota Radio Discussion Forum 2 11-10-2008 03:38 PM
Power Supplies LukeB General Scanning Forum 23 10-30-2008 06:17 PM
BCT-15 Power Question for Mobile Install nickcarr Uniden Scanners 4 10-28-2008 08:47 PM
Any ideas for mobile power solution... kmacka General Scanning Forum 10 12-07-2007 04:23 PM
Antenna Switch - default/no power setting Pro-95 Antennas and Coax Forum 1 08-29-2004 05:10 PM
