Make your own. Buy some coax panel bulkhead adapters of the type coax connector you plan to use.
It would be better if you had a metal top on the rack or box that you plan to mount the radios in. Most
antennas are designed to work with a ground plane under them. A plastic or fiberglass case is not
the ideal mounting surface for this use.
There are a number of sources for both the antenna mounts, antennas and the coax connectors.
The best one for you will depend on where your located. Much of this can be mail ordered.
Jim
Originally Posted by muskrat99
where can I get one of those patch panels? That may be the ticket!!!! Basically I'll be using one scanner with a dedicated 800 antenna, another scanner with a stock antenna and a couple of others covering freq specific stuff like aircraft etc....I would guess those jacks are isolated from each other?
